Headlight out...please help
Alright guys, i was doing the ALT. Foglight Mod and if it wasnt for ignorant ass it would have been done a long time ago...anyways i was messing around with the fuses while they were still hot and i go in front of my car and notice my left headlight (right if your lookin at them) is out...could it be a fuse doubt it with my luck....if not please give me the solutions...and the dreaded question how much...GEEZ I was so happy i got the mod to work and then i F it up.....
At least i got it to work
There is a headlight fuse for each side but if you were just using the fuses from the inside slot 8 and slot 9 it will not affect that. Slot 8 I believe is ACC and slot 9 is the Instrumental Panel.
Hot as in has power or temperature wise?
if there is one for each side then it could just be a blow'n fuse right?, i did notice one of my fuses on the add a circuit to be blown but i thought i tried it again with a fresh fuse
update...when on low beam it kinda will flicker for a little bit which makes me think it's not a burned out blub, the high beam will also flicker....all the fuses seem to be ok, any ideas?
FIXED, and yet again, Bxscig comes through huge for me, thanks man, it was just a fuse and I was lookin inside the car for it instead of under the hood...again, dont under estimate the mind of a ignorant human being
AmplifiedDetails
09-24-2015 02:55 PM
