Head Gasket Leaking Oil but car runs fine.
Car was leaking A LOT of oil from different areas. Mechanic determined it was from O-Ring and replaced the O-ring and the oil filter housing gasket. Afterwards, it was determined Head gasket also has a very minor leak. Car runs fine.
Addition Info. Crank and Cam seals were replaced 15k miles ago.
Car is 1999 Tl with 202K.
Additional Work I have recently done:
New Paint
Transmission oil flush
Brakes resurfaced
new radiator due to leak
New Paint
Brakes resurfaced
Are you asking for advice or just letting us know..? ![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
I think that was the confusion: were you asking for confirmation
justnspace (12-04-2015)
Id get a 2nd opinion on the Head gasket leaking oil. Its more likely the valve cover gasket leaking oil than the head gasket. If the head gasket was leaking oil id say you would more than likely have bigger problems
eaglesfan398
12-05-2015 04:57 PM
