H&R Springs
H&R Springs
My car has 18" Motegi MR7's on it. 18*7.5 w a +45 offset. I thought the offset would be high enough for the wheels to fit inside the wheel well, but they dont, they stick out a little. Is there anything I can do to have the rims fit flush?? Anyways if I keep the set up w/the wheels sticking out will the H&R sport springs work w/o rubbing, or will I have to go with the OE?
I had the same setup, however, my wheels really didn't stick out at all. A tiny bit more then stock.. but really not noticable.
Anyway, like I said, I had the same rim setup as you and i have the H&R Sports and I had zero rubbing problems. I was running 225/45/18 Michelin Pilots. You never mentioned the tires size you had, but if it's close to that you should be OK too. One thing to note is that you may need a camber kit.... I did.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
