H&R sport springs with CT sway bar enough??
Originally posted by LiLDaVe
How about if i just get the H&R sport springs without anything else??Will my ride be??Will my stock shocks be affected in any way??
thanx a lot for your help wilz...just one more question if i get the H&R sport springs and the CT sway bar i dont need to get my stock shocks replaced??And is that a good combo- the H&R springs with CT sway bar??
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Originally posted by jmai
I have to add that u'll need better tires than the OEM Michelins. They'll screech when u corner b/c the their sidewalls aren't stiff enough.
If you are going to get springs AND sways... get new tires. The stock tires will NOT provide the grip you need with both of these mods. If you are just going to get springs... you should be OK. Just sways are a little more questionable... but both should require new tires.... no question.
As I've posted before.... I have seen horror stories on here and acl.com with people who had stock tires and suspension mods. Stories from fishtailing, to spinouts... to accidents... b/c the stock tires do not provide the grip necessary.
FYI.... I have the H&R Sports with the stock shocks. The stocks will wear out a little faster with springs.. so you will need to replace them eventually... but you should be fine for a while.....
I just want to know if it is a clean drop? The H&R sports are a clean drop or what? I just want to see pics..thanks guys. Are they as smooth as the Eibach Pro-kit? Well just wondering before I go off and spend money on the Pro-kit, just wanted to know if the H&R are just as good, then I can save me some money for other mods...hahaha
![Jump](https://acurazine.com/forums/images/smilies/jump.gif)
![Flash](https://acurazine.com/forums/images/smilies/flash.gif)
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
www.geocities.com/juniorbean/TL_S.html
click on my sig for pix of H&R drop
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
