group buy gauge's problem
Old 03-22-2004, 06:37 PM
I installed the set of gauges from the group buy and after driving for about ten mins. or so the gauges start to flicker a little then start to flicker a lot. Only happens in full indiglo not in reverse indiglo. Anybody have had this problem? What could be the problem?
Old 03-22-2004, 07:50 PM
yield2s's Avatar
is your dimmer turned all the way up?
Old 03-22-2004, 08:11 PM
yes, there bright for about the first ten minute's. Then they flicker pretty bad.
Old 03-22-2004, 10:02 PM
Tatewaki's Avatar
something is loose, or the transformer is going south
Old 03-22-2004, 10:22 PM
Show me da MONEY
muffaburn's Avatar
mine do the same thing after about an hour or so. I also noticed that when they start to flicker if I turn the radio up they flicker even more, hmmmm....
Old 03-23-2004, 05:22 PM
Same thing happens to me. There only a week old.
Old 03-24-2004, 11:17 AM
hzm82's Avatar
sounds like the transformer. Mine works beautifully.
Old 03-24-2004, 03:05 PM
Where can I get a new transformer?
Old 03-24-2004, 07:03 PM
Are the gauges hard to remove if I have to remove them?
Old 03-25-2004, 12:23 AM
hzm82's Avatar
the gauges are easy to remove. They peel off and you just scrape the two sided tape off with your nails. Any kind of warranty on this stuff? You can try ebay or do a search for transformers. Most places that sells the gauge also sell the transformer.
Old 03-25-2004, 03:47 PM
I bought them from a member here. And i'm sure there is no warranty, since the group buy was a couple of year's ago. Anybody have gauges from procarparts.com? If so, how are they?
Old 03-25-2004, 04:33 PM
hzm82's Avatar
I have the gauge that procarparts.com sells. My works great, not dimming or anything. I believe we both can use the same type of tranformer and switch. I remember a website where you could buy the transformer and switch seperately, did you search on procarparts.com?
OculiAquilae
11-19-2018 02:24 PM
GhostTL09
09-19-2015 01:57 PM
PortlandRL
09-14-2015 12:01 PM
brandnewcolony
09-12-2015 10:39 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: group buy gauge's problem
