good customer relations from a .COM???????
Hi Claude,
I believe I found your order for the Eaglite 9006 80w bulbs. It isn't really common to have a bulb go out, but if it is defective, it will usually blow out very soon after installation, which is good since you're still covered under warranty.
In any case, I'm going to send you out a new pair of the Eaglites. Usually we only send one replacement bulb, but this way you'll also have a spare.
As for the MAX 55w bulbs, because the wattage is lower, they should have a longer lifespan. (One month for the Eaglite 80 watt bulbs is NOT normal though - those should last much longer too.)
If your mailing address has changed, or if you have any other concerns, just let us know. Also, please give our best to everyone at Acura-TL - great bunch of people!
Bill W. - Customer Support
www.midnightmoose.com
your source for performance lighting accessories!
HeloDown
09-08-2015 06:51 PM
