Funny odor coming from heating/air vents
Guest
Posts: n/a
What's up guys. I've got this musty/mildewy smell coming from my A/C-heating vents every time I turn my car on for about 30 seconds then it goes away. Any clue on how I can get rid of it or what is causing it?? Have any of you ever experienced this problem?? Any answers would be helpful, thanks.
Platinum's whip.
Platinum's whip.
It smells like that usually when you turn off your AC after using it for a while. It's very common with Honda/Acura. Known solution... bare with it till it goes away. Seriously, there isn't much you can do about it.
Y2K silver TL, non-navi
Factory style full body kit + spoiler
Volk Racing Versus Campionato SS7 18 x 7.5 52 offset w/ Toyo 225/40/18
38% window tint
Valentine 1
38% window tint
Valentine 1
I think you can get it cleaned at the dealer. The odor is from you a/c condensation. I had an Integra before and it was cleaned once for free. Not too sure if that is still applicable.
I believe if you turn off the a/c a couple of minutes before you reach your destination, it could reduce the odor build up.
Your evap drain probably got clogged so you have gunk growing in it. Have to run a cleaning solution like simple green or some other cleaner maybe with a little bleach to kill the growth inside your evaporator and unclog the drain line. Happens to other cars besides hondas also!
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by valuetl:
Your evap drain probably got clogged so you have gunk growing in it. Have to run a cleaning solution like simple green or some other cleaner maybe with a little bleach to kill the growth inside your evaporator and unclog the drain line. Happens to other cars besides hondas also! </font>
Yo value, How do I run the cleaning solution??
Platinum's whip.
Moderator Alumnus
Used to happen on my old Accord. I would flush the core with clorox and clean water then put some soap in it. That would keep the smell away for awhile. Make sure you use a brand of soap (dishwashing liquid) that you like the smell!
BTW - My drain wasn't clogged but the slime would build up in it. Guess due to a bad design.
[This message has been edited by Lawaia (edited December 21, 2000).]
Remove your glove box and access the filter. Have to cut the cross brace and pull out the filter. This will give you access into the evap core assy. Use a flashlight to look inside for any nasty growth inside. Use a spray bottle with cleaner to clean it out and flush out the gunk, also check the drain onto the driveway and make sure it flows water freely.
1 Post
Thats strange to me for the TL to have this problem.I thought it was mostly for cars that don't have the A/C filter.
I know the smell all to well it smells like piss. I had this in my 90 Accord & in my 94 Accord.Since I run the A/C most of the time except when its real cold do to allergies. I have not had this problem with my TL yet. I have run the A/C all of last spring this summer & fall. The question is do you have the yellow(REC)pushed on? I find that I don't use the (REC)button on the TL like I did in the Accords.I use the auto climate control more then manual mode.The TL A/C works much better so the only time I push the (REC) button is if its a strong order or smoke. The Accord I would turn off the (REC) about 10 min before I turned off the car & this smell was not there the next time I turned it on check your yellow (REC) button to see if its on.
My car had that same smell, kinda like a mildew smell. I took it to the dealer and they sprayed some lysol into the fresh air
intake located underneath the grill by the wipers. Just turn your temp to low 60's and turn on the fan, then just spray it directly into the air intake located under the passenger side wiper. The dealer said that mildew tends to grow in the ducts since our
climate control is constantly turning on and off the AC, ever since then the smell is gone. Take your cars to the dealer, they should do it free for you. Goodluck.
<font face="Verdana, Arial" size="2">Originally posted by shooter:
I always turn my AC off BUT leave the fan on right before I reach my destination. I haven't noticed any bad smell so far ...</font>
Go to a auto supply store..they sell something that cleans out all the mildew and condensation smells from the vents.. explain to them the problem, they will direct you to the item..
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Pics of my TL
Guest
Posts: n/a
Thanks for all the responses guys!! Hopefully, the smell will be gone soon.
Platinum's whip.
Platinum's whip.
I'm getting this smell too. Even after 50,000 miles. I'm using the Lysol in the vents and that takes care of it for the most part but when I park in the garage and take a minute to get out of the car, the smell in the air in the garage stinks. Is there someplace else I need to spray besides in the interior vents and the fresh air vent?
Oracle Apps/Database Dude
Ken and everyone else, this is a common problem on Hondas/Acuras, It is a bacteria that grows on the condensation when you have the a/c on. To kill the bacteria do the following:
1. when you are approaching your destination (5 miles) turn you heat up ALL THE WAY.
2. alternate thru the different vents for a minute each defrost, leg area ect.
3. Make sure the AC is not on.
What this does is the heat kills the bacteria. It also does not promote condensation when your car reached its destination. the AC unit does not condense hence no food for poor bacteria, besides the bacteria would have been fried by now.
Try it and let me know..
And the Lysol smell is an added "temporary" plus. Better than that awful odor....
¤ Club Inspire ¤
Originally posted by ElegantTL-S
are you supposed to do this everytime before you reach your destination???
But if I end up having to do this everytime, that would be fine because the smell/odor was awful and embarassing.
On the way!
If you didn't adjust the temp back to 70 something before shutting off the car, the vanes will still be set to channel air through the heater core when you start up next time. That's why you don't smell the mildew (mildew doesn't grow in the heater core).
Running your car with the temp set to 90 will do nothing more than get you hot. It doesn't kill or clean anything.
solution
I had the same problem, took it to the dealer, and they sprayed lysol into the air intake under the passenger wiper, while turning the temp all the way down and fan to max. should cure the problem
snorf
11-04-2019 06:44 AM
