front wheel Vs. rear wheel......
I was running against this F150 V8 earier... well anyway, we lined up.... lights went green, we both punch it... guess wat, he kept up with me till my VTEC in 1st kicks in.... of course so on, i pulled away... but the thing is.... I figure our HEAVY front wheel drive really have a big disadvantage... cuz no matter how good you try, still, once the car lift up, the front weight all transfer to the back, all the front tires do are spinning.... but the rear wheel, they just punch and go.... yes yes yes, i know most of yall will say, GET BETTER TIRES..... well but i am sure, if a rear wheel car change to a better tires, they will be EVEN BETTER!!! I guess thats the thing about front wheel drive cars.... oh well!!
Actually, in a straight line drag race FWD will get much better traction than a RWD, especially a pickup! This is because a RWD pickup will have lower rear vehicle weight over the drive wheels.
RWD cars have an adventage in drag racing (or ANY racing, fortaht matter), because of the power of todays's cars, you can hardly control the spin you have on the FWD cars, you can't use all the power because that would just waste time doing wheelspins
RWD cars, you can drop clutch at whatever RPM yoou like to get the desirable launch RPM and wheel slip, and then you can just go full gas utilizing every bit of power you have since the weight is transferred to the rear, keeping the rear tires planted
while it seems silly to me to be drag racing in our TL's, if dragging in a 4 door sedan is your thing, I'd defintiely recommend looking into a RWD car, as they do fare better in such instances. But, as far as safety and handling for the majority of the drivers I have seen, a FWD car will them them into enough trouble.
just my 2cents.
just my 2cents.
6G TLX-S
An excellent comparison between fwd and rwd is by looking at the I35 and the G35. Both of them contain Nissan technology, and have almost comparable engine outputs.
I35 - 255hp VQ V6 fwd on fwd platform
G35 - 260hp VQ V6 rwd on rwd platform
This is the closest-to-best test for fwd vs rwd ever, because the technology differences between different car manufacturers do not come in play here.
Our TL have approx 60/40 weight distribution as does the typical Ford F-150 but Ford only have 40% of its weight over the rear drive wheels. More weight over drive wheels = more traction
Originally posted by STi
you're the one that stole my 330Ci's wheels!!
haha jokes aside, i loved them so much, very nice rims
just wondering, why do you have a ferrari sticker on your car, it just doesn't fit in?
that was an option, but I decided to go for Euro parts on the engine. I put the Euro air meter in there, JC tuning for the euro HFM, 5 angle valve job, titanium pieces in the head, milled the engine to a 10:8:1 ratio, port and polish, cams, bigger injectors, Dinan intake, better flowing exhaust manifolds, cats, and exhaust. and thats about it. of course I changed everything in the engine too including the head gasket, valves, springs, retainers, lifters, tensioners, thermostat, thermostat housing, bolts, etc... it had perfect compression and it beat E46 M3's and gave M5's their run for the money (beat one guy in a 2001 M5 but dunno if he knew how to shift) also the car had some weight reduction done.
Originally posted by samkws
um...don't ya know FWD cars acclerates faster than RWD cars?? don't laugh..it's true...
it's all about physics
last time i checked, Ff=mFn, and when a car accelerates, the Fn in the back increase, and thus more friction (or traction, for that matter) on the other hand, the Fn in the front decreases, therefore losing traction
and to put all the power down, you need traction, so unless the RWD car you are talking about is the '86 corrolla and the FWD car you're referring to is the TL-S, a same car with the same weight and the same engine (same everything except drive format) the RWD can kill the FWD car any day
ya where did you learn your physics?
Obviously to make a direct comparison between FWD and RWD, we'd have to "level the playing field" by making all other things equal. Using the G35 and the TL-S as examples, we have different engines, different gearing, different weights, different coefficients of drag, etc. There's no easy way to tell how much each of these factors into acceleration from a stop.
With that being said, I've been to the dragstrip probably 100 times in the last 5 years and I can tell you that RWD is a MAJOR advantage in accelerating from a stop -- especially when you're talking about enough power to overcome the traction of the front tires when you plant the gas pedal.
Here is an expert's view on the age old debate of FWD vs RWD. http://www.canadiandriver.com/articles/jk/020619.htm I agree 100% with J.K., especially with the part on the decrease in corner handling ability of FWD, but Houstan CL was talking about a straight line drag.
well...
when a FWD car going uphill is always easier to pull than a RWD to push up the hill...
so does that make sense??
well...
if you want to accelerate uphill in a FWD car, you may break the front tires loose, and the car may sway, or if the traction control kicks in, you lose momentum
that could simply be subjective, i don't feel my TL-S pulling stronger uphill than my less hp 330Ci, in fact, i feel more confident because the RWDs are more stable uphills
Comptech Freak
but if i put 2 same car with 100hp...different layout
one is FWD, one is RWD
the FWD will get the nod coz of lower weight and without a driveshaft to the rear...
it's a fact that FWD cars pulls easier than a RWD when going uphill...especially from a start...
but on the down side...FWD is not as safe as RWD on downhill...
okay, this may be true in your example, but if you say they're the same car, shouldn't they have the same weight as well?
a reason for this is because if the engine has only 100hp, it cant even break the FWD's front tires loose, then in this case the FWD would win
but if their hp were raised to over 150hp where FWDs would spin off of the line, the RWD should win
where did you get the fact about FWDs going uphill? this doesn't make much sense to me, but i could be wrong
is there a source? i'd like to find out once and for all
nanos
11-12-2015 08:41 PM
09-04-2015 08:03 AM
