Front Passenger caliper??
Old Aug 25, 2013 | 09:49 PM
  #41
3.2TLc's Avatar
Question Have ya tried this lately.....?
Originally Posted by TLer trash
With everything bolted back together, (except keep the wheel off), step hard on the brake pedal, let up and immediately go and see if it released. If the rotor is hard, or impossible to turn by hand, open the bleeder. If the drag on the rotor doesn't change, you need a caliper. This assumes that the pads move freely in their mounts, and that the caliper slide pins/bolts are lubed and and moving freely as well. If the caliper releases when you open the bleeder, you've got a hydraulic problem; typically the brake hose.
Hey BoriTL, seems like something has been overlooked along the way.
Get back to the basics. If the only problem is with the front driver's caliper sticking and you've apparently replaced every available part with new.....{(pads, caliper a couple times, fluid many times, rotor, bracket and retaining/mounting hardware, pin & bolt, brake hose line, anti-seize lube and more fluid to fully bleed system again)}. What's left ???
Old Aug 26, 2013 | 11:34 AM
  #42
TLer trash's Avatar
I think you should take back the caliper you have and get a "semi-loaded", or "friction-ready" caliper. This will have the mounting bracket, hardware, clips, pins, etc, and will be rust free, and properly lubed. Typically you should add a small amount of lube where the pads touch the abutment clips. This has got to solve your problem or else you've left out, or given some incorrect info. Or you have got the worst source on the planet for calipers!
Old Aug 26, 2013 | 06:25 PM
  #43
BoriTL's Avatar
I took the caliper back! Not even going to bother trying to put it in yet. Replacing the hoses is the only thing left, might as well since changed everything else. Hopefully that will solve the issue, they should be in a couple days.
Old Aug 26, 2013 | 07:39 PM
  #44
3.2TLc's Avatar
Ah, ..... thought ya already tried that !
Your luck may take a turn for the better.
Old Aug 27, 2013 | 07:41 AM
  #45
BoriTL's Avatar
Would the lines really have such an effect?? wouldn't it be noticeable when your bleeding them if you had a line issue
Old Aug 27, 2013 | 11:20 AM
  #46
TLer trash's Avatar
You might notice restricted flow, but often times they'll bleed just fine. However, when you open the bleeder, whatever pressure a hose is holding back will be released immediately. I thought you already tried this. If a hose cures this, I gotta believe the bleeder was plugged up completely, and not releasing pressure.
Old Sep 3, 2013 | 03:55 PM
  #47
BoriTL's Avatar
So changed the hoses and still having the same issue. One side stays locked, I free that side up with a flathead and the other locks up right away. Any ideas? Extremely exhausted dealing with something that should have been so easy.
Old Sep 4, 2013 | 04:56 PM
  #48
TLer trash's Avatar
I really wish I'd explained the difference between a bare caliper and a loaded one earlier. I think that's your problem. Slides, pad mounts, I don't know. What's left? A loaded caliper(or friction ready) eliminates everything except the hydraulics.
Old Sep 4, 2013 | 07:32 PM
  #49
BoriTL's Avatar
Friend mentioned proportional valve but didn't find much info on it online. Any ideas?
Old Sep 5, 2013 | 12:38 PM
  #50
TLer trash's Avatar
My idea is to forget about the hydraulic part of the brake system. You ruled that out when the caliper still dragged with the bleeder open. Unless I missed something, you still don't have the reman brackets, new pins, hardware, etc. that come with a friction-ready or loaded caliper.
Old Sep 5, 2013 | 01:40 PM
  #51
BoriTL's Avatar
New hardware came with the calipers only thing not replaced are the brackets. Find it weird that one locks up, I free that one and than it looks the free one up.
Old Sep 5, 2013 | 04:02 PM
  #52
3.2TLc's Avatar
Do the brake pads float freely within the caliper's retaining brackets ?
It could be that as your problem persists, that the pads are not fitting well and binding. How were the old original pads wearing previously ???
Old Sep 5, 2013 | 07:11 PM
  #53
BoriTL's Avatar
I could flick the pads and they fall out. The drivers side pad was way more worn than drivers with the old calipers. The new ones came with all new hardware.
Old Sep 6, 2013 | 07:43 AM
  #54
BoriTL's Avatar
Not sure if it matters after i bleed the pedal its pretty solid, but once i turn on the car to see if the calipers are sticking, it turns spongy.
Old Sep 6, 2013 | 11:57 AM
  #55
TLer trash's Avatar
You probably have some air in the system. Go out and do a few stops on gravel and get the abs to engage a few times. Then rebleed. I don't see how this will affect your brake dragging though. At this point, I think you need professional help. Find a good independent shop as opposed to a dealer or franchise/chain.
Old Sep 6, 2013 | 01:49 PM
  #56
Nicks2001tl's Avatar
Your missing something. Maybe its time to get some pro help.
Between the calipers, brake lines and numerous times bleeding your system you should have great brakes already.
Old Sep 6, 2013 | 02:11 PM
  #57
BoriTL's Avatar
Something i've done numerous times on other cars and had no issues until the TL. Frustrating busting my butt to get a car i really wanted and having a stupid issue like this. I've had the car more in repair than actually driving it.
Old Oct 1, 2013 | 04:28 PM
  #58
BoriTL's Avatar
Any ideas?? i'm about ready to throw in the towel. Have replaced, brakes, brakes lines, calipers, brake hardware, and rotors but yet i still have one of the front tires stay locked. I've bleed the crap out of it both methods with 1 man tool and having the wife pump pedal but still no luck. Honda buddies tell me Proportion valve could be screwed up but no info online of this happening to anyone previously. any help is greatly appreciated. Trying to avoid hiring someone as can't afford right now.
Old Oct 1, 2013 | 04:45 PM
  #59
3.2TLc's Avatar
Hey BoriTL, ya gotta be thankful for having a wife with patience to help.
But, there's a point when you've spent more on parts and time than what the inconvenience is worth. All I can say is go back and look at the original problem and attempt to step through the process one last time and then ya may have no choice but to hand the job over ??? Sorry, IDK.
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
hand123
Sep 10, 2015 09:29 AM
08 NBP TL
Sep 8, 2015 08:49 PM
nuldabz
Sep 3, 2015 05:49 PM
