Front camber kit- what's your reading?
What's your front camber reading after an alignment, and how much is your drop. I bought an extreme camber kit from somebody online and and I just read that it's +1.5-3.0 Anyways, last time I remembered, my front camber isn't that bad as oppossed to my rear. Do I need that much? That might be too much with say a 2" drop huh?
Lemme know what your front camber is and what drop, I'd appreciate it. Thanks.
Who Needs a Type-S?
2000 Honda Accord v6
17x7 CL-S Wheels
Dunlop SP Sport 4000 215/50-VR17
Eibach Sportlines
Factory Dampers
Front Left
Camber: -0.4 degrees (Factory Spec: -1.0 to 1.0 degrees)
Caster: 3.0 degrees (Factory Spec: 1.8 to 3.8 degrees)
Toe: 0.02 degrees (Factory Spec: -0.08 to 0.08 degrees)
Front Right
Camber: -1.1 degrees
Caster: 2.4 degrees
Toe: 0.01 degrees
Front Total Toe: 0.03 degrees (Factory Spec: -0.16 to 0.16 degrees)
Rear Left
Camber: -1.6 degrees (Factory Spec: -1.0 to 0.0 degrees)
Toe: 0.08 (Factory Spec: 0.00 - 0.16 degrees)
Rear Right
Camber: -2.3 degrees
Toe: 0.09 degrees
Rear Total Toe: 0.21 degrees (Factory Spec: 0.00 to 0.32 degrees)
I need a rear camber kit too, but the rear tires hardly get worn much..
17x7 CL-S Wheels
Eibach Sportlines
Factory Dampers
Front Left
Front Right
Caster: 2.4 degrees
Toe: 0.01 degrees
Rear Left
Rear Right
Toe: 0.09 degrees
1fatcrxnem1
22
06-01-2018 01:23 AM
nuldabz
09-03-2015 05:49 PM
