Frequency of topping up motor oil
Old 01-16-2004, 07:21 PM
dee diddy's Avatar
just wondering if it's normal to be topping up ~0.5L of oil every month? i usually fill it up till the oil is between the min & max lines on the dipstick or maybe a lil past halfway. i'm running Mobil 1 5W-30. does synthetic burn up faster? i never paid attention to checking the fluids that much when i was on conventional oil, so i don't really have a comparison.
Old 01-16-2004, 07:22 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
shouldnt be burning whatso ever, i run 8000 miles and the level doesnt go down between changes
Old 01-16-2004, 07:55 PM
yield2s's Avatar
ya I'll second that! hondas don't burn unless somethings wrong.
Does your antifreeze look like a rootbeer float? or you smoke blue when you step on it?
BTW how many miles do you have? and when did you switch to synthetic? I ask because it's common for a old motor to develope leaks at the seals after a switch to syn. do to the removal of the sludge build-up.
Old 01-16-2004, 10:06 PM
dee diddy's Avatar
everything else is running fine & my friends are into the practice of topping up every so often. i'm over 34k km now & i switched at when i did my last oil change about 4k km ago on halloween. i did a top-up in the beginning of dec with my remaining 300-400ml of Mobil1. it brought from a bit over the min line to almost halfway.
Old 01-17-2004, 07:28 AM
ChucksCL-S's Avatar
Look at my sig.....I don't burn any at all! I'd get that looked at.
Old 01-17-2004, 11:48 AM
Busta Nut's Avatar
After looking a fsttyms1's post...............I forgot what we were even talking about!
Old 01-17-2004, 12:34 PM
Busta Nut's Avatar
Oh yeh.......................Honda engines just plain do not burn oil. Toyota's don't either, so you have a problem my friend.
Old 01-20-2004, 08:48 AM
dee diddy's Avatar
i just started checking my fluids after i had a discussion with a friend who topped up the oil in his bimmer and also on his mom's accord. would it be similiar to fuel consumption where driving conditions have an effect? cuz i do 100% city driving and i gotta do lots of idling.
Old 01-20-2004, 11:05 AM
lover and fighter
r10apple's Avatar
I average over 25k miles a year and I have no problems, either...Your baby is sick...
Old 01-20-2004, 11:11 AM
LS14ME2's Avatar
What!!!!!!
We agree with one another????
My TL does not burn a drop of oil either at 55K....
Tight as a drum....
Old 01-20-2004, 12:24 PM
Bear2Day's Avatar
Check your driveway, Most park in the same spot everytime. Then look up where it`s comming from.
Old 01-20-2004, 12:30 PM
Strannik's Avatar
My 2000 now has 52k. Around 42k I had to put 1/2 quart in. Now, after 2 last oil changes (at 45k and 50k) there was no problem - no oil disappeared. So it seems like it just kind of stopped happening. I have no leaks or any other engine problems.
Regarding having it fixed - good luck! Every engine manufacturer says that it is OK to add some oil, sometimes up to 1/2 qt every 1000 miles. So that's what you will hear.
Old 01-20-2004, 12:37 PM
fsttyms1's Avatar
burning will occur if the conditions are severe (alot of time at high rpm, or extreme temps). but it shouldnt be a reoccuring thing. ive gone through over a quart of oil racing about 20laps but durring that the engine spent most of its time around or past redline(9000rpm) but as soon as i drove it normally it wouldnt use a drop i would still recomend getting it looked at if it continues to do it
uzzmaan
03-12-2024 10:03 AM
12-07-2020 05:39 PM
kmarqueling
10-03-2015 01:14 AM
09-17-2015 08:57 PM
ghuns
09-16-2015 04:26 PM
Quick Reply: Frequency of topping up motor oil
