Fog Light question, HELP FAST!
ok so i ordered some Texon yellow fog lights for my 02 TLtypeS.... the problem is that the seller said he no longer has the 9006 55W bulbs, but he does have the 9006 80W if i would still want them.... somebody tell me what to do...should i get my money back or what
Stay with factory wattage, or you might melt the wiring or the reflector in the fog lights.
If I be you get HID.
I got HID on my wife car .
HID is not that much more money, less longer, and alot brighter
^ Only setback with HID fogs is that it might make visibility worse ... more reflection than actually "cutting" through the fog via contrast (ie yellow > white light). Just a thought.
But definitely get your money back. Do not go with higher wattage since the factory wiring is not designed to support 80W.
I have 3000K Piaa Ion yellow fogs (proper wattage) and just love it, especially in winter with snow on the ground. Super yellow on the lower section from the fogs and HID white on upper level from low beams. I swap out to 5000K halogen bulbs in summer, but stay within car spec in wattage.
sockr1
10-01-2015 02:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
