Fog
The New 3 Series Coupe
Fog
Hi all, I have just purchased a pair of fogs but have already connected all the wires but one, the wire that requires power from the ignition ( whenever the ignition is on the power runs through)... The question is... where do I connect this wire? I've opened up the fuse box on the driver's side and did know where or which one to connect to... Can someone help a fellow TL'er out? thanks.
fuse
I installed my radar detector the same way, If I remember right I used the 8th fuse on the right, (drivers side fuse cluster), do a search on radar detector installation and you should find your answer...good luck ..UWgrad
why do you have an ignition wire???
are you sure its not a parking lamp wire? because if its hooked up to the parking lamps then they should automatically shut off with the parking lamps when you turn them off from the light stalk or take your key out of the ignition
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Originally posted by Inspire
Thanks man... But I thought the fog lamps requires more power than 3amp?
If your set-up has the fog lights wired directly from the switch with no relay in between then you need to rethink where you tap into with the switch.
