figured out my electrical issues-actually messing with my tranny
Subscribe
Dec 19, 2007 | 03:24 PM
i got a check engine light on today. as if my electrical issues werent enougg. pulled the code and its a p1705.
shorted transmission range switch-short probable cause
short circuit condition
failed transmission range switch.
seems like my car is a electrical nightmare. any recommendations guys? please help me out. i am REAL good with electronics etc. i should be able to understand. and i also have the shem. manuals thanks to acurazine! haha so please..help me out
Reply 0
Dec 19, 2007 | 04:09 PM
i found the peice, that wwas messing up. iw onder how much it costs
Reply 0
Dec 19, 2007 | 04:19 PM
try the OEMAcuraparts.com or one of the other dealers that advertise here
Reply 0
Dec 19, 2007 | 04:22 PM
if only i could find a part number
Reply 0
Dec 19, 2007 | 04:26 PM
find the part in the diagram where its at and it will give you the part #
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Reply 0
Dec 19, 2007 | 11:35 PM
i found it. i just pulled the part from the box and go it. the price is 19.99. i hope this works. i wonder what caused it to go out....
Reply 0
Mar 9, 2008 | 08:42 AM
Quote: i found it. i just pulled the part from the box and go it. the price is 19.99. i hope this works. i wonder what caused it to go out....
Phee,
Where did you find this? I have the same code and I haven't called any dealers yet, but I can't find it on any of the diagrams or parts sites.
Thanks!
Reply 0
Mar 10, 2008 | 12:52 AM
its actually a relay. if you open up your hood there is a black box right in front of the drivers side. pop that box open and there is a grey square, thats the relay. My transmission was replaced along witht his item so i dont know for sure which was the culprit. my car is an electrical shitbox
Reply 0
Mar 12, 2008 | 07:09 AM
Oh, ok thanks, phee! I'm beginning to wonder about mine too. The locks don't always work and my little security light on the driver's door isn't working, but I tested the alarm to be working. Also I have a pink headlight on the driver's side. Nice....
Reply 0
Mar 13, 2008 | 08:47 AM
I recommend you change your headlight bulbs. The pink is an early warning sign that they are about to go out. Replace them in pairs and go with the kaixen bulbs. The reason your car will not lock sometimes is probably because you leave your lights on when you exit the car, flip the lights off and luck away! As for the little bulb not blinking.... Could be another blown bulb. Take the door panel off and replace with your favorite color led. You may need a sodering iron. Search around for this mod, someone has done it.
Reply 0
Mar 13, 2008 | 09:06 AM
Quote: I recommend you change your headlight bulbs. The pink is an early warning sign that they are about to go out. Replace them in pairs and go with the kaixen bulbs. The reason your car will not lock sometimes is probably because you leave your lights on when you exit the car, flip the lights off and luck away! As for the little bulb not blinking.... Could be another blown bulb. Take the door panel off and replace with your favorite color led. You may need a sodering iron. Search around for this mod, someone has done it.
Mine locks just fine with the lights on
Reply 0
Mar 13, 2008 | 05:04 PM
^^^^^ Agree.
The car will lock with the headlights on. The headlights will shut off by itself after a few minutes. Next time you disarm the car, the headlights will come back on automatically.
Reply 0
Mar 13, 2008 | 05:45 PM
I think it's 15 seconds from the doors being locked that the lights shut off
Reply 0
Mar 14, 2008 | 09:01 PM
Yeah, it locks with the lights on. And I guess the security system is working even though the LED isn't. Oh, and I switched positions on the bulbs and it's definitely bulbs. 6000K Kaixen's are on the way!! Thanks all!
Reply 0
May 15, 2011 | 11:53 AM
Phee, did replacing that relay fix your problem?
Reply 0
May 15, 2011 | 01:01 PM
the transmission was failing. thats what was wrong.
Reply 0
Subscribe
