few basic D4, D5, SS questions
2003 TL
yeah I know... noob shit here... but I've always wondered...
1.) Can you switch from D5 to D4 while in the middle of driving?
2.) Can you switch from D5 to D5/SS mode while in the middle of driving
3.) Does any of this damage your tranny, or is it sort of designed for being able to do this?
Its perfectly fine. You wont hurt any thing on any of your questions.
2003 TL
thanks
may I suggest a read of the owner manual, which also list the max up and downshift speed limits for SS
Avoid using SS to slow down- brakes are for that
Its fine to use for fun in the mountains and backroads
Avoid repeated downshifts into 2nd and 3rd at max rpm/speed- that puts the hurt on the clutch packs and these trans have enough problems already
Use auto D4 in traffic and hills, keeps it from hunting for 5th
Here is the free owner book online- click year then model- wait for pdf file, use hand icon and index to go to any subject
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
also register with acura as the owner 1-800-382-2238x5 ask if any open recalls or extended warranty you need to know about
plus reg with the online system- different system- http://owners.acura.com/registration...erstepone.aspx
Need cars VIN for both of those, the 800 is customer care and sends out recall notices if one happens in the future- so they need a real address to contact owners
^ how you said use D4 in traffic and hills. Wouldnt that lower the mpg well not for hills cause 5th in hills is not the best gear but your car should know that right and go into the right gear for the uphill anyway. For downhill it will probably go to 5th depending on the speed.
5th is overdrive and loses mileage in the wrong power band.
In stop and go traffic it shouldnt be trying for 5th- 4th will keep it in the lower gears
Approaching a big hill- 4th has some torque to get up the hill
If you cant figure out to use D5 downhill you shouldnt be driving!
READ the owner book- I dont make this stuff up!
Just to double check, it WILL NOT damage the trans in any way by switching from D5 to tiptronic and vise versa WHILE the car's in motion? I figure w/ all the problems these trans are causing us, it would be more pertinent to come to a complete stop, THEN choose D5 or tiptronic, then proceed. Am I just "wasting time" or will doing so help extend and protect the trans?
PLEASE read the owner book!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The trans is electronically controlled- not a cable connect like older cars had
All you are doing is sending a signal thats a request for shift- the computer decides to give it to you or not
Its fine to shift back and forth SS to D5 at will- it automatically goes into the gear it was on the D5 side,,if you were really in 3rd it goes to 3rd--if freeway cruise it will stay 5
follow my other advice on not downshifting and use of brakes- thats what will preserve your trans far better than wild guesses and stopping for no reason-
thats actually putting more wear on trans as it now has to accellerate thru 2nd and 3rd again--get it?
2003 TL
I've read the owners manual several times over the years, and I don't remember it addressing the switching from D4, D5, SS etc while in motion *shrug*. I guess i didn't read it well enough eh?
But whatever, I know now thanks to the replies..
free owner book!!!! click your year then model- wait for pdf file to open
Use hand icon to navigate the index
Never hurts to read it again--
Plus thats where a little common sense should come in.
Come to think of it, if that really was the case, there'd be a lockout until you come to a complete stop. Or whatever criteria it's looking for. Can't believe I didn't think of this before...
I've switched on the fly from D5 to SS at freeway speeds with no complaints from the tranny. Like someone else said these cars are mostly fly-by-wire with sophisticated electronics and rev limiters, not your dad's 72 Celica. I think if there ever was real problem with at-speed switching Acura would have said so in bold print as that would be a real basic.
Word of caution about SS if you have previously driven other manual cars: Always push the lever forward, not back for higher gear. My previous car was a stick Nissan so I'm used to moving the shifter backward from 3rd to 4th. I was heading to Tahoe in the TL and I was in SS 3 on a fast climb. I'm not sure what my RPMs were but when I cleared the top I moved the lever backward thinking I was shifting to a higher gear. It just seemed natural like in the Nissan. Everyone in the car lurched forward and the engine screamed and suddenly my ability to handle the car came into question. I was going too fast for 2nd gear but still under the rev limit. Then came those most hurtful words from my wife: Honey, do you want me to drive?
you are joking right?
Getting it Done
No to be a thread stealer, but would driving daily in SS hurt the tranny? I almost NEVER drive regular, I'm always using SS to shift early at like 2k-2.5k, and it works as well I stay away from 5th in the city.
I do 20/80 highway/city driving and in a tank (not counting the 50 extra miles from when the light goes on) I can get 23mpg, not to shabby hehe, I haven't done a seafoam or injector cleaning either, that should bump up the mpg, same with the AEM CAI I'm about to buy
the problem with daily use is if you downshift a lot into 2nd or 3rd to slow the car-- instead of using the brakes.
The gear selection allows you to be on the torque band for the speed you are at and accellerate off the corner in the correct gear.
If you are nort racing thats of little concern to street drivers who simply push the pedal and go to the next stoplight
Downshifting causes heat- that puts wear on the weakest part of the system
2500 rpm is a normal shift point for the auto trans under light throttle
Experiment with that in D5 and see how the shifts compare to you in ss
You should get better mileage letting the car run things!
Seafoam will help- the cai will take away as you get leadfoot with most of them~
new plugs after foam and its like a new car
Traded in my
Mine jerks around a bit when in D5..kinda like the manual jerk when you let off the gas..in D4 and in traffic..it doesn't jerk around so much so I keep it in that. and that way it's not reachin for 5th so much. plus the manual says to drive in D4 mhen not at freeway speeds anyways so I'll listen to my manual
yeah! someone who read and follows the book of instructions!!!
D4 keeps it from trying to find 5th at the lowest possible speed- for fuel savings
Have to remember to put it back in d5 when traffic start moving above 45 again
Very easy to be in 4th at higher speeds and not realize it, losing gas mileage
You can also use d4 on a steep downhill to help control speed and save the brakes till you need them..instead of riding the brakes
Getting it Done
