FAQ: 06-07 AV6 Transmission 'Swap'
Old 01-09-2015, 02:08 AM
  #201
nguyen25's Avatar
Originally Posted by nguyen25
So to be clear,
in the second step; removing filter assembly, and lines (#'s 11, 7, 22, 21, 10, 24, 12, 15, 26, 20, 6, 13, 14) is not necessary, right?
and I have an '02 TL Type-S, should fourth step be ignored?
Lastly, does bringing the wiring harness from the TL transmission to the AV6 require any electrical work (splicing wires/soldering)? or will the wiring harness connect like plug n' play?
Old 01-09-2015, 12:38 PM
  #202
MBP 03's Avatar
So to be clear,
and I have an '02 TL Type-S, should be ignored?
If you're going to keep the transmission fluid warmer and spin on filter setup from your TL, you're going to have to unbolt the warmer assembly while leaving all hoses attached to it before being able to drop the transmission. Once the transmission is out, you will unbolt the TL filter assembly and transfer it over to the AV6 transmission. When the AV6 transmission is back in the car, you will then bolt the fluid warmer back on.
There is no splicing / soldering involved when swapping over the wiring harness.
Old 01-11-2015, 08:14 AM
  #203
vmaxlucy's Avatar
New post .
Thanks to all who have paved the way way for my own AV6 swap.
It's colder the hell this week so looking forward to a day or two in the shop.
Found a doner trans with 76,000 km from an 06 Accord delivered from Calgary to Saskatoon $900.00. 10l Amsoil sythetic atf (DW-1 Equivalent) -100.00, AV6 filter and rear main seal.
Good to go.
I will update upon completion.
Thanks again for the time invested into the, FAQ: 06-07 AV6 Transmission 'Swap'
Old 01-16-2015, 11:19 AM
  #204
nguyen25's Avatar
Hey everyone.
Just got the my TL back from the shop. The swap went well and the car drives well. Gear changing is quicker and smoother than the old transmission. I was fortunate to get a hold of a transmission with low mileage. The transmission I bought was from a 2007 Honda Accord V6 with 99,000km.
Thanks to everyone who contributed to this thread!
Old 01-17-2015, 12:29 PM
  #205
zerepyort's Avatar
Does this also work with the TL Type S (TLS or TL-S)?
Old 01-18-2015, 01:49 PM
  #206
nguyen25's Avatar
Yes. I had the swap done on my 2002 TL Type-S
Old 01-18-2015, 07:31 PM
  #207
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
^ Yep it's actually easier on the TL-S because of the lack of PS Speed Sensor.
Old 01-21-2015, 07:38 PM
  #208
01TLindaworks's Avatar
Hello guys
My 01 TL is currently in the shop and the AV6 transmission is installed. The only issue it's having is its throwing code P1705. The TL sensor is installed and still throwing the code. Any suggestions?
Thanks guys!
Old 01-22-2015, 02:58 PM
  #209
Nizmo_max's Avatar
anyone can confirm if 2005 honda odyssey transmission is the same as 2006 odyssy trans.? TIA
Old 01-22-2015, 05:32 PM
  #210
Originally Posted by 01TLindaworks
Hello guys
Thanks guys!
Please someone? I'm stuck
Old 01-23-2015, 02:17 PM
  #211
Hey Wasup
I am in need of some help. I just bought a 2007 AV6 transmission 68,000 from LKQ and its installed in the car now. I am getting code P1705 with the TL range sensor. I bought a new one hoping it would remove the code but nothing. Is there a specific way to calibrate it? Any suggestions? Just about every sensor has been switched. I really hope the transmission is not messed up
Please help
Old 01-24-2015, 07:24 AM
  #212
5th Gear
onemilehigh's Avatar
Hey Wasup
Please help
What is your email? I can send you some info on troubleshooting the indicator. I can't post attachments here.
01TLindaworks (01-24-2015)
Old 01-24-2015, 08:37 AM
  #213
Eduardo.uceda@yahoo.Com
Thank you very much! I will keep you posted!
Old 01-25-2015, 08:57 AM
  #214
vmaxlucy's Avatar
Thumbs up swap complete
AV6 is in and operating. I kept the av6 filter setup but switched the cooler on top of it SHIFTS SMOOTH AS SILK.
I replaced front and back motor mounts along with trans. mounts.
Only issue is while in gear there is a significant vibration but goes away when driving. Could it be cheap motor mounts that I installed?
Old 03-06-2015, 02:34 PM
  #215
7th Gear
komike's Avatar
Is it better to buy a rebuilt or a used w/miles tranny?
Old 03-07-2015, 12:29 AM
  #216
Skirmich's Avatar
^ Rebuilt is better But far more expensive.
If you can get your hands on a sub-100K unit it would be the best compromise. Always check the ATF on a used unit before buying:
Cherry Red/New ATF Smell = Weird (In most cases you wont find this and if you do its vary shady)
Strong Red/New ATF Smell = Good Trans
Black Red/ATF Smell = Not Good, you could bargain it.
Black/Burned ATF Smell = Skip it!
Old 03-07-2015, 10:31 PM
  #217
Cord's Avatar
If anybody is looking to do the swap on their own,this video should be useful...
Part 1
Part 2
Old 03-09-2015, 07:48 PM
  #218
Trader122312's Avatar
Where have you guy purchased the cooler gasket. Does anyone have the part number. The guys at my local autozone cant find it.
Old 03-12-2015, 08:57 AM
  #219
Cord's Avatar
25812-P7W-A01
Old 03-13-2015, 08:21 AM
  #220
3rd Gear
Arieas's Avatar
Hi All,
Looks like my 03 Acura TL is joining the ranks of the dearly departed.
Was hoping someone might have contact info for 03blackbeast.
I'm in the Indianapolis area and would love to use the same mechanic he had do his swap.
I sent him a PM 2 weeks ago, but sadly no reply.
I've talked to a few other mechanics that were unwilling to do the swap, still calling around in the hopes of finding somebody.
This seems to be pretty a pretty straightforward job, however its a bit outside my comfort zone to do solo, and i'd rather pay a qualified mechanic the $600 to do it right.
Thanks for any and all help.
Old 05-22-2015, 03:25 PM
  #221
ttvegas2002's Avatar
Hello everyone, just bought 07 av6 tranny with 64k miles on it ( that was claim by LKQ), now my question is should I crack the case open to replace the internal filter or you guys think it should be good as for 64k miles? Tranny should be in next week so I just want to find out more information before I get start on it. 2002 tl type s. Thank you
Old 05-22-2015, 08:29 PM
  #222
Cord's Avatar
You should replace the filter regardless...its a 10$ part...but good peace of mind...clean filter is always better.also it's much easier to do so out than in the car
Old 05-22-2015, 09:52 PM
  #223
Sorry, I was talking about the filter inside the transmission, right next to the clutches
Old 05-23-2015, 12:25 AM
  #224
musiclevelz5's Avatar
You need a lot of specialty tools to open the case and you also need the service manual so you know where everything goes when its time to put it together. Its a huge hassle to open the case just to replace the internal filter. Once the case is open you might as well do a full rebuild because you did 80% of the work already...
If it was me, I would do a full rebuild or nothing.
Old 05-27-2015, 04:32 PM
  #225
my tranny from LKQ just came in, so excited to do the swap.
Wrapped in plastic
Old 05-28-2015, 09:28 AM
  #226
Chojun's Avatar
Excellent, now mail your old one to ISIS in Iraq
Old 05-29-2015, 07:23 AM
  #227
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Make sure to have the deliverer drop it from about 30k feet.
Old 05-29-2015, 06:15 PM
  #228
lolz, will do.
Does anyone has the torque spec for bolts on the solenoids, flexplate to TC and transmission to engine?
Old 06-04-2015, 03:00 PM
  #229
AegeanBlueTypeS's Avatar
Trans Range Switch - Question
Hi everyone!! I have been hanging out on these forums silently for a while now and figured this is a good time to speak up and say hello before I ask my question.
I am getting ready to do this swap as my 02 Type-S is starting to have TRA issues. I would like to be sure I am crystal on everything before I start to get my hands dirty.
-- When it comes to adjusting the rage switch how do I go about doing this? --
I have done mechanical work before but have not had to do anything like this. Working on a FWD vehicle is new to me.
Thanks in advance!!
-ABTS
Old 06-05-2015, 08:39 AM
  #230
MilwaukeeDave's Avatar
You'll feel it pop into the right place. There's a small detent pin in there.
Old 06-05-2015, 02:27 PM
  #231
MBP 03's Avatar
Mark the location of the range switch mounting bolts on the sensor before taking it off the TL transmission and use the marks as a reference point when mounting it on the AV6 transmission.
Old 06-06-2015, 05:42 PM
  #232
5th Gear
03type-s503's Avatar
Hello new to this. When I completed my av6 swap I took it out for a spin and everything was smooth. As it came to shift from 2nd to 3rd gear my D5 lights starts blinking and check engine light comes on. I scanned it and a p0780 code comes up as shift malfunction. I thought I had a bad shift solenoid on the AV6 transmission so I swapped over from the old one and im still having the same issue. My question is did I miss somethin? or did I get a faulty transmission? Please help!!
Old 06-07-2015, 11:49 PM
  #233
Just an updated on my swap
Got the transmission installed, replaced rearmain seal, axle seals, TC seal, new solenoids, new transmission filter ( i kept the old AV6 transmission filter setup). Been driving for 100 miles now and everything seem good, shift very smooth. Thank you very much for the great DIY guys, I saved myself 700-1000 in labor.
Waiting for the transmission to come
LKQ trnsmission came in
Side to side swapping out parts
Installing new transmission
New transmission on custom jack
Installing transmission
Top view of engine and transmission
Everything are back together
All four wheels on ground and ready for test drive
After test drove
Old 06-08-2015, 11:19 AM
  #234
5th Gear
After test drove
Was everything liter
Old 06-08-2015, 11:21 AM
  #235
5th Gear
Was everything literally a plug and play after you finished you didn't have to do anything like reset anything? You just turned the key and go?
Old 06-08-2015, 12:31 PM
  #236
Pretty much everything plug and play, the only I noticed on my vehicle right now is hestitation when engine is cold, seem like from second to third. After couple minutes when engine warm up then vehicl shift fine. I'm going to double check all my work just to make sure all the vacuum lines and plugs are in correctly.
Old 06-08-2015, 01:44 PM
  #237
5th Gear
I'm having an issue with not wanting to shift out of 2nd but I think I just got a bad transmission. When you changed the filter on the AV6 transmission did the oil come out clean or was it dirty?. I think that's the problem with what I got It wasn't a burnt smell but just dark red/black. But good job on your car man get some more life out of these beasts.
Old 06-09-2015, 10:50 AM
  #238
The filter and the oil on the AV6 was pretty dirty and very dark/black color.
So I've noticed on the vehicle when cold start the engine vehicle seem hestitation on first and second gear, tried to accelerating but the rpm seem not going pass 2500-3000 rpm. Once the car get moving then sfter that there was no issue what so ever.
One other things happened to me yesterday is that the tcs, cel came on while driving on the highway right after I decarb/throttle body cleaning ( took aiut the air inlet tube and sprayed the throttle body cleaning inside the throttle while engine is running and revs with the cable dtc p0740 came on after that.) I did clear it and just going to wait to see if the light come on again.
Does anyone know how to fix the hesitation on low gear 1st and 2nd when engine is cold ( after engine been sitting for a while). Thanks guys
Old 06-09-2015, 04:24 PM
  #239
Update!
So with the hesitation problem that I'm having right now. So today after work I decided to start up the car and let it idle for 5-8 minutes with the hesitation that I'd experienced this morning went away. At first the idle was rough and you can see the vibration from the engine but after few minute later the engine idle normal again and that's when i drove home from work and didn't feel any hesitation from 1st or 2nd gear like this morning. Can anyone help me out and tell me what's happened? Is it possible I got a clogged EGR valve or the EGR port in the IM?
Old 06-16-2015, 12:13 AM
  #240
5th Gear
Quick question does anybody know what to use to clean the cooler/warmer on the transmission?
Quick Reply: FAQ: 06-07 AV6 Transmission 'Swap'
