Exhaust resonator
Old 09-22-2003, 07:57 PM
nolimitazns's Avatar
Exhaust resonator
quick question does removing the exhaust resonator violate inspection tests? also does it get very annoying or is it a low rumble?
yea dont have much money right now and i dont really want a new exhaust until my warranty goes out.
Old 09-22-2003, 10:23 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
it shouldnt affect your inspection test's. there only purpose is to take certin frequencies. i have had mine removed for 2 1/2 years now. ther will be a little deaper exhaust note with the factory exhaust, nothing at all anoying. once you get a aftermarket exhaust , thats when it becomes louder
Old 09-23-2003, 12:21 AM
PeterUbers's Avatar
How do you remove it?
Old 09-23-2003, 12:40 AM
hzm82's Avatar
Muffler shop
Old 09-23-2003, 09:21 AM
'Big Daddy Diggler'
bigman's Avatar
just remove the pre muffler, but leave the resonator. I thought my car sounded great with both off till i heard someone driving it and it had no bass at all, but made a buzzing ricer sound. If you get rid i\of the pre muffler it will have a little bassier sound and add like 2 hp up high.
Old 09-23-2003, 09:37 AM
Tls22's Avatar
Bigman: Is the pre muffler is right before the 2 rear muffler?
Old 09-23-2003, 11:17 AM
'Big Daddy Diggler'
bigman's Avatar
yeah, its that big muffler right before the 2 mufflers, and the resonator is the skinnier piping thats a lil bigger than the exhaust piping. Trust me i have tried many different setting before settling on a balance of power and noise.
Old 09-23-2003, 11:45 AM
Tls22's Avatar
Thumbs up
Thanks.. Maybe I'll give it a shot my self and see how it goes..
Old 09-23-2003, 01:30 PM
fsttyms1's Avatar
i have both removed, but i also have comptech exhaust.
go here and click on the one that says sound
http://www.acurainspired.com/old_gal...ra-pics&page=2
Old 09-23-2003, 04:07 PM
TL Navi's Avatar
Fsttyms how did you remove the resonator on your car ? is there a DIY on this and is it simple to take off and put it back on if i am not happy with the sound? Thanks
Old 09-23-2003, 05:12 PM
njtls's Avatar
when you added the magnaflow res....did you take out the smaller res?
Old 09-23-2003, 05:32 PM
so remove the pre muffler but leave the resonator on? Isn't there like 2 resonators, a larger one and a smaller one? I hear people say remove the small one?
If you can can you take a picture of what the pre muffler is and where the 2 resonators are?
I'm thinking of bringing it to pepboys to get the resonator off.
Old 09-23-2003, 07:52 PM
fsttyms1's Avatar
there is no easy way to get the resonators off, well i take that back there is. A SAWSALL but any way, if you get down and look under your car just infront of the passenger side tires there is what appears to be a small muffler, that is one of them. and between that and your cat there is a small round one. the one BIGMAN is talking about that he removed was the one closest to the rear tire (small muffler). i have both off and its just a deaper sound with the factory exhaust on. not really any louder. but if you have an aftermarket exhaust on then it gets louder. just ceck th elink i posted earler
Old 09-23-2003, 08:31 PM
'Big Daddy Diggler'
bigman's Avatar
There is only one pre muffler, and one resonator. The pre muffler is the small muffler looking thing closer to the middle of the b pipe. The resonator is closer to the Y pipe. Do not remove the both of them. The car will sound fine inside, but you will get a buzzing sound, louder when it's cold out. I removed the pre muffler and it sounded great. Leave the resonator, because it will be less restrictive and filter out the raspy high pitched sounds. I dont have either because i have a custom cat back setup with one 2 ft magnaflow resonator. I dont recommend doing a full cat back unless you have a non Type S car. The Type S exhaust piping is big enough to maintain tourque and give HP with mufflers and removal of the pre muffler. To remove the pre muffler just go to a muffler place and get a pipe put in for like 30 bucs. Hope this helps.
Old 09-23-2003, 09:16 PM
thanks guys i appreciate it.
eastsideride
10-15-2015 04:26 AM
joflewbyu2
10-08-2015 11:16 AM
merc009
09-29-2015 03:06 PM
prbori
09-27-2015 01:37 AM
Rcelestino93
09-23-2015 10:01 PM
Quick Reply: Exhaust resonator
