engine swap
has anyone done a type s swap on their tl. found a engine cheap and just wondering what steps i need to take before i jump on it.
never heard anyone do that before. it would be interesting to see it done.
Just curious...
How old/miles on your engine presently..?? what are the reasons you think you need an engine switch..?? |
i am sure it could be done, but there are other components, including electrical ones, that would have to be changed also, including the ECU. I dont know how you would get a list of all the parts you'd need.
what kind of swap? tl to tl-s ? tl to nsx?
go for it! ud be the first!
I think this swap would be the most easiest one.
Your basically swapping from a J32A1 engine to J32A2. ;) Good luck. |
isn't it basically just the intake manifold and ecu that are different? displacement is the same..and im pretty sure compression is also the same..
Originally posted by spyder5786 isn't it basically just the intake manifold and ecu that are different? displacement is the same..and im pretty sure compression is also the same.. J32A1 - 9.8:1 J32A2 - 10.5:1 |
if its a whole engine then about the only thing you would need would be a ecu,
also wondering if the tranny and mounts are correct plus the wiring.
Originally posted by TLFROGY also wondering if the tranny and mounts are correct plus the wiring. Remember, both engines are essentially the same. |
yup...just some higher compression domed pistons, to my understanding...
