Engine Analysis/Alternator Test Results
Hello All,
I had an engine analysis done earlier in February of this year. Here are the results.
I was advised to check what is the bench mark that the alternator should be running at. Is 26% for an alternator on the 2GN TL or should I change it very soon?
If the image doesn't load in this post, the direct link is
http://i42.tinypic.com/a2qi3k.jpg
Please share your comments,
i dont get the point in this test, if anything more should of been done, like voltage drops from batt to alt, and neg from bat to block, output tests, load test, current draw etc..because by the looks of ur rpm its just at idle, and under no load, with like accessories on etc....soooo yea.
09-15-2015 06:44 PM
