door speaker wiring
door speaker wiring
ok, i did it on the drivers side fine, but for the life of me i cant get a wire run into the dash from the passengers side. i stick the wire in and i just cant get it. so i want to use the stock wiring. can i just cut it off the wiring harness, and instead splice it to the wire to my amp? ghetto i know
Its harder to see but its something you can get to. get a good light up under the dash area. Remove the fuse panel cover and the kick panel and look. Its about the best advise we can give.
Try taping a somewhat stiff wire (like is used in fish tapes) to it & push gently to see if you can get it through. Just don't force it so you don't damage anything.
polish_pat
09-25-2015 12:24 PM
