Don't kill me, diff between tlp & tls
I need 2 more gears
I did some searchs and didn't get what I wanted. What is the main differnece between tlp and a tls engine wise that is. From what I know a tls has a higher compression ratio than a tlp and bigger throttle body. Is that it? Why does the tls have 35 more hp than the tlp? Its redline isnt much higher and a bigger TB doesn't produce an extra 35hp. What would have to be altered on a tlp to match the tls HP?
Not Asian
Do a search for dual stage intake. I came up with https://acurazine.com/forums/showthr...l+stage+intake
You can turbo anything
The compression is a biggee...that can change horsepower considerably in the same engine, along with different timing adjustments
