Does a TL-P sit higher that a TL-S?
Old 01-17-2004, 02:45 AM
Dai
Dai's Avatar
I've got a 02 TL-P w/ stock CL-S wheels on it.
Whenever I see a TL-S, it looks lower than what my car looks like.
Am I just seeing things or is there a difference in the ride heights??
(BTW, i'm sure that the TL-S' that I see are NOT lowered)
Old 01-17-2004, 12:06 PM
Deity42's Avatar
TL-P wheels are 16's, and TL-S and CL-S wheels are 17 inch. Maybe that explains the difference?
Old 01-17-2004, 02:43 PM
vipvop's Avatar
the wheel size shouldn't matter, the tl-s wheels just have less tire on top of them.
Old 01-19-2004, 01:34 AM
vtec 6300's Avatar
The TL-S rims are sportier looking and the tires are wider which gives off a lowered stance.
Old 01-19-2004, 04:54 AM
hzm82's Avatar
TypeS are running 17 inch rims but they also have low profile tires. So the whole diameter of the wheels are the same between the stock 16s and 17s.
Old 01-19-2004, 04:59 AM
hzm82's Avatar
You are wrong. TLS (17x6.5) and TLP (16x6.5) The TLS rims are NOT WIDER.
However, the CLS rims are 17x7, so they are wider. I don't see how that would make your car give off a lowered stance tho.
Old 01-19-2004, 05:14 AM
hzm82's Avatar
Re: Does a TL-P sit higher that a TL-S?
The TL-S and TL-P have different stock springs and shock absorbers. TL-S spring part # is 52441-S0K-A51, while the TL-P spring part # is 52441-S0k-A02. Which leads me to believe the TLS is lowered then the TLP.
Old 01-19-2004, 07:27 AM
hemants's Avatar
1. I believe the perceived difference is just that, a perceived difference.
2. Stock TLP's have a SLIGHTLY larger diameter of wheel 25.68 inches vs 25.5 but I doubt you'd notice this.
Old 01-19-2004, 08:46 AM
TL-S driver
goldendragon576's Avatar
also, check to see if there is a body kit. When you install a body kit, it makes the car look about 1-2 inches lower. Could that be it?
Old 01-19-2004, 02:09 PM
larryr20's Avatar
check this out. It may answer some questions.
http://www.new-cars.com/2002/acura/a...fications.html
Old 01-19-2004, 02:17 PM
I do know for a fact that the TLS seats sit lower than the TLP. I could't fit into the TLP for lack of head room. No problem with the TLS's headroom, unless I wear a cap.
FlDave
Old 01-19-2004, 03:10 PM
TL-S driver
fldave, how tall are you that you need that much head room?
Old 01-19-2004, 04:17 PM
GoldenDragon, When I was looking at Tl's the sales person noted that I had no headroom and recommended I try the TLS as the seats are firmer . AT first I thought she was just trying to get me into a more expensive car, but she was right. After trying out several TLP's and several TLS' I bought the TLS( my wife agreed I should get the one that had more head room!) I'm 6'2" with a longer than normal torso.
FlDave
Old 01-19-2004, 06:10 PM
hzm82's Avatar
Well according to this website, the TLS is indeed lower then the TLP, It maybe be because of the different spring/shock and it's heavier. Or a combination of those.
Old 01-20-2004, 01:02 PM
MikeTL-S's Avatar
2003 CL-S and 2003 TL-S use the SAME stock michelin tire- 215-50-17.
Old 01-20-2004, 01:47 PM
hemants's Avatar
":Well according to this website, the TLS is indeed lower then the TLP, It maybe be because of the different spring/shock and it's heavier. Or a combination of those."
No, according to the website height and ground clearance are the same!
Old 01-20-2004, 02:06 PM
kevin cody's Avatar
I havbe tl-p also and have type s wheels, I just dropped it but prior to that the frot did look a little higher then the type s. Diff struts and springs. Lower it!
joflewbyu2
08-18-2019 10:38 PM
emailnatec
29
09-28-2018 04:27 PM
MetalGearTypeS
08-29-2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
San Yasin
09-29-2015 10:52 AM
Quick Reply: Does a TL-P sit higher that a TL-S?
