Does anyone's engine feel heavy?
My engine feels so heavy and I was wondering if anyone else feels this. It's like the engine just does not want to go. Also, there is a huge delay from the time I push the gas pedal to when the engine actually rev's. Is there anyway I can adjust this? I noticed this when I drove our 94 Accord today. The car's pedal is a lot more sensitive. Same with my cousins 99 maxima.
Retired MOD
1 Post
Re: Does anyone's engine feel heavy?
Using a 12mm wrench, turn nuts to loose them up. then adjust by pulling and letting the cable sit a little tense, like about to move the throttle rotor. Hold it, then tight the nuts. That's it.
Re: Re: Does anyone's engine feel heavy?
Originally posted by Bitium
yes is very easy. on your throttle body, there are two throttle rotors with metal cables. The black one is cruise control. The gold one is the one you need to adjust.
Retired MOD
1 Post
Originally posted by Dimsumo
So the delay is cause from the slack of the cables....So wouldn't tighting it make the gas petal more "sensitive"
Retired MOD
1 Post
Originally posted by patrick
Bitium, so does this cable become loosen over time, or is it something the dealer's mechanic fiddled around with? BTW, what do you call this cable? Thx
don't know what the cable is called.
Ok, I was looking at it and I didn't know how tight to make it. It seems pretty tight but then again, I dont know squat about it. Also, I dont want to mess it up so that my car wont start or rev's up to 5000 rpms. If I went to the dealer, what can I tell them to do?
Thanks bitium
Thanks bitium
Retired MOD
1 Post
Thanks bitium
Thanks bitium
the worst that could happen if too tight (meaning the butterfly is open) would be that you will idle at 1k+ rpms. Don't think you want to do that, but it would NOT cause damage to the engine, uless you leave it like that for a long time(days or months) which I still think it won't affect anything major.
BTW while u doing this, better have to engine running. Cause one time me and Allan[VTEC]TL tryin to doing this on his friend SC400.
After we tight it up and start the car. the SC wad idle at 5000 rpm.
Retired MOD
1 Post
My engine feels so heavy and I was wondering if anyone else feels this....
Do you get a huge delay while in SS?
Originally posted by eggbert
Yeah.. it sort of does that when not in Sport Shift. You can put it to the floor and it's like it has to take a big gulp of air before it decides to downshift.
The cable is called throttle cable. The spec for cable deflection is between 10-12mm according to the service manual. You need to push the throttle link toward the throttle level until there's no clearance before checking. Hope that helps. But I think it's better to let the mechanic to mess around with it.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
