DIY: Side Skirt Extensions
11 Attachment(s)
I have been thinking about doing this for a while and looked up some other DIYs from other forums. This is what I came up with.
Approx time required: 30 min to 1 hour I bought this: 2x 8ft pieces http://www.homedepot.com/h_d1/N-5yc1...1#.UH7Xp29U6r4 I cut each one to the length of the OEM side skirt. I rounded the edges with my orbital sander. Then I painted them gloss black. Attachment 50071 Then I used 3M heavy duty (5lb capacity) double sided tape along the length of the skirt. I mounted mine so that they stick out 3cm in the front and 3cm in the rear. This matches the amount that my front and rear wheels stick out past the OEM side skirts. You can mount them however far out you want, and make them whatever shape you want. That's all up to you. After I stuck it to the OEM side skirt in a position that I liked, I used 1" self tapping screws (about 10 of them) along the length of each side skirt. It's pretty damn solid. Unless someone really steps on it. This is my version 1. Maybe down the road when I get more time, I'll laminate it with carbon fiber and add some curves or something to it. ***If you do not have OEM body kit side skirts, you can probably still use the same method to make an extension. Home Depot and Lowes have PVC/Composite planks in 3/4" thickness which will look awesome. I used the 5/16" thickness because I am already so low.*** ***Please excuse my rear wheels. My aftermarket rear wheel is getting a new tire so I had the stockies on for a few days.*** ***THESE DO NOT INTERFERE WITH THE OEM JACK POINTS*** Attachment 50072 Attachment 50073 Attachment 50074 Attachment 50075 Attachment 50076 Attachment 50077 Attachment 50078 Attachment 50079 Attachment 50080 Attachment 50081 Enjoy! |
Looks good, ima have to put my own twist on this one though :p. Thinking about using diff material but looks just as good.
Haha I encourage everyone to take this idea and run with it. Show me what y'all got.
Interesting interesting... Gonna have to visit my friend Home Depot... I like :)
Thats pretty Dope
nice. been waiting to see when someone would do this.. lol
lot of miata guys do this as a cheaper solution to having no side skirts options to go with their r-package front & rear lips. how's the fitment on that CF hood? it looks like you should probably get it sanded and clear coated. |
Thanks guys. The hood is just my OEM hood with CF on top. I'm not done with it yet. Still gotta sand and clear coat, but I've been putting it off. Sanding epoxy is like sanding steel :whyme:
looks good, has that whole diffuser look to it. Would like to see it on a TL without the OEM kit, not sure if it would look good, or like i stuck some home depot plastic onto my car haha
Been wanting to do something similar to this with carbon.. good start!
Looks nice
Looks really good.
And I like it, but i personally would cut a little in around the midle so it 'flows' better with the kit. and a quick question: Do you have the OEM kit? or something else because I see the Modulo badge. |
Thanks everyone. Yeah it's the OEM kit. I just like the Modulo badge because it's not something you see everyday. Modulo HCP is basically like Honda's OEM accessory company.
To be honest, I wasn't sure about the extensions when I first put them on. But I'm REALLY glad I did it now. They look great. Especially with my 10 inch rears back on :biggrin: I'll take more pictures tomorrow. |
well I can't wait to see those pics!
nice
Has anyone attached these to your acura Tl,, 2012-2014 models i guess.
suppose to be universal but i dont know ... Honda Acura Front Body Kit Lip Canards Flippers Splitters | eBay |
real fresh, gives side skirts a little more definition
Not gonna lie those look dope
