DIY:Door peeling (experimental way)
Old 10-26-2008, 09:36 PM
Keep It Simple in
SLushhYYY's Avatar
WHAT YOU NEED:
-Gorilla glue or some kind of glue that glues foam.
-TWO pieces of flat wood
-adjustable pipe that you can twist to make longer or shorter.
****SORRY NO PICS OF the PEALING BEFORE
Step 1. Wet the foam first with an ear cleaner and apply gorilla glue to sperated parts.
Step 2. Take piece of wood and press it against the part that is pealing
STep 3. Apply wood to both sides and tighten pole putting enough pressure to seal the peel
STEP 4. Let sit over night AND......
YOUR DONE!!!!!!
The following 5 users liked this post by SLushhYYY:
AMart83 (09-07-2014), ErickUa5 (09-07-2014), KatabaticSaint (11-29-2011), leeps (11-28-2011), TheMightyQuinn (12-17-2012)
Old 10-26-2008, 09:53 PM
Just chillen..
FL3.2TL's Avatar
LOL. Nice! Clean interior BTW
Old 10-26-2008, 10:44 PM
n1njai's Avatar
Oooh....I like it! Gotta do this tomorrow.
Old 10-26-2008, 10:49 PM
Awesome Memeber
SSTL's Avatar
lol nice and simple, let us know how it holds up.
Old 10-26-2008, 10:52 PM
Keep It Simple in
SLushhYYY's Avatar
You might need some tweezers to push down some of the rubber/plastic material that was squished upward on the armrest. Hopefully it lasts for awhile
Old 10-26-2008, 11:29 PM
-Arsenic-
02type-s's Avatar
One of mine needs this too
Old 10-27-2008, 05:47 PM
Bob_F's Avatar
Very cool! Thanks for sharing that.
Where did you get the adjustable pipe?
Old 10-27-2008, 06:10 PM
Keep It Simple in
SLushhYYY's Avatar
Its the pole that holds up your shower curtain...
Old 10-27-2008, 06:27 PM
Bob_F's Avatar
Thanks. It thought it might be a shower curtain rod.
Old 10-28-2008, 10:22 PM
Keep It Simple in
SLushhYYY's Avatar
Ill give an update in a month or two
Old 10-28-2008, 10:59 PM
Chillin' in my trailer
CL-Slick's Avatar
Great idea man, very creative. I will have to do this on the CL.
Old 11-21-2008, 01:35 PM
thinhthan's Avatar
what if you need to replace the switches? wouldnt the door be gorilla glud to the switches
Old 11-21-2008, 01:48 PM
mrchan625's Avatar
haha this is great i was just wondering how i could fix mine too great write up!
Old 11-21-2008, 02:08 PM
Trackruner228's Avatar
Dude thats an awesome idea.
Old 11-21-2008, 06:27 PM
Stimpy's Avatar
I agree. I noticed that the material covering your speakers is a little on the darker side. I got ahold of a steam wand and a steam cleaner and cleaned 'em up real nice (all four). Comes out great - you should try it! Take the panel off the door first if you plan on it tho.
Old 11-21-2008, 06:38 PM
I'm a thrill seeker in my
TheMegalodon's Avatar
I'm confused....Where exactly did you put the glue? I heard that gorilla glue foams quite a bit, so wouldn't it have come gushing out of the two separated parts? I have some gorilla glue, but I'm waiting until spring to fix my passenger rear door.
Old 11-21-2008, 07:11 PM
Keep It Simple in
SLushhYYY's Avatar
It foams? Just put the glue on the inside of the peal where the foam is and push to seal the peal.
P.S MAKE SURE THE GORILLA GLUE GLUES FOAM AND PLASTIC
Old 11-22-2008, 04:07 PM
06 Anthracite TL
erdoc48's Avatar
Just a quick reply having fixed one of the door handles on my old (now my brother's) 00TL: if the Gorilla Glue foams out from the seam when drying, use an X-Acto knife to simply break away the excess glue- it worked really well when I did the repair > 2 years ago, and it still holds to this day.
Old 11-22-2008, 11:04 PM
Trixboomer's Avatar
XLNT!
I have the same issue on my 02 TL-S I thought I had fixed it with some hot glue but your holding / setting device is sweet and simple I'm well on my way to the same fix myself.
Thanks for the post.
TRIX
Old 01-27-2009, 11:44 PM
frogsc25's Avatar
Yea thanks for that now i can get it in shape.
Old 04-01-2009, 08:31 PM
Keep It Simple in
SLushhYYY's Avatar
Still looks exactly as it did the day I did it.
Old 04-01-2009, 10:32 PM
Glad to hear it! I'm stoked to do mine once it's warm enough...that and the stupid triangular defrost vent on the left side of my steering wheel. Damn thing is popping out for whatever reason and won't stay down.
Old 04-01-2009, 10:35 PM
Hello Officer
It's Clutch's Avatar
thanks.. ive been getting that too in the back
Old 04-05-2009, 03:57 PM
Always Working In
my.daily'tl''s Avatar
That's an easy diy. I was wondering exactly how to tackle it. Thanks for the great write up and pics. And still holding up? I'm adding this to my diy list right away. Thanks.
Old 04-05-2009, 06:33 PM
Hello Officer
i was able to do this with a funky clamp.. Good write up SLushyyy
Old 04-05-2009, 07:13 PM
Keep It Simple in
SLushhYYY's Avatar
Yah they're still holding up.
Old 04-05-2009, 10:33 PM
luismorales's Avatar
Great way to do it! I'm gonna try it one of this days.
Old 04-05-2009, 10:35 PM
Hello Officer
^Let us know ur results
Old 04-06-2009, 07:43 AM
The Dumb One
Rockstar21's Avatar
i wonder why most get it in the back?
carrying alot of passengers most of the time?
my back interior is mint while the front doors are.. egh...
i'll need to do this to the handles in the front.. thanks!
Old 07-11-2009, 02:42 PM
MikePA's Avatar
WHAT YOU NEED:
Why ear cleaner?
Old 07-11-2009, 03:05 PM
Mista Juice's Avatar
Originally Posted by MikePA
Why ear cleaner?
i was just thinking the same thing.. i know one, if not both, of my rears are separating now and need to do something like this..
Old 07-11-2009, 03:20 PM
Keep It Simple in
SLushhYYY's Avatar
Why ear cleaner?
Lol a Q-Tip to wet the foam. Gorilla glue works better when its moist.
Old 07-11-2009, 07:14 PM
speedemon90's Avatar
NIce, this has happened to the back right door of my car, im gonna try this out when i get a chance. Great write up
Old 09-06-2009, 08:42 AM
MikePA's Avatar
I did this repair to my rear, driver side door a few weeks ago and am waiting for the glue to cure on the front, driver's door, I thought I'd repeat what Slushyyy said, the glue only needs to be put on the foam (after you wet the foam with water).
Old 11-28-2011, 12:23 AM
leeps's Avatar
Thanks SLushhYYY, i had a similar thought, but chose to work on the arm rest independently. I took the panel off, removed the armrest and also removed the plastic part with the ashtray and window switch. I used your wood idea (I wrapped a cloth around it though) and used 3 C-clamps to clamp the material directly to the plastic foundation of the armrest. I had already purchased Gorilla Glue, so I was glad to read your post and see that is what worked for you as well.
I started out looking a salvage yards for a replacement arm rest and of course, none would sell me the armrest separate from the door panel, AND all the armrests were as bad or worse than the one I had!
Thanks again
Old 11-28-2011, 07:54 AM
kill you till you die
yeedatoy's Avatar
No need for wood or anything. Just squirt the glue in and put the c-clamp on the door and the other end in the ashtray or the indention by the window switch...scrape off excess glue after it foams and you're done. you don't need a block if you don't tighten the c clamp enough to mutilate your door.
Old 11-28-2011, 10:38 AM
00RubieTL's Avatar
Mine also is in that location. Im am also puzzled on why this is always happening on the rear passenger side. Glad I found this post, Ima tackle this, this weekend.
Old 11-28-2011, 06:17 PM
Original Owner / Oct 1998
Carbuff's Avatar
I never noticed it, but all FOUR arm-rests are separating on our TL!
I wonder if anyone will notice the shower rod missing for a few days?
Old 11-29-2011, 12:26 PM
swllen_cu's Avatar
WOW! Just saw this thread! I'm going to be doing this soon! All of my door panels are peeling in that same exact spot!
Old 10-17-2012, 11:52 AM
'02 NBP TL-S
Chanrith's Avatar
Thanks for the write up on this! I tried super glues without clamps or shower rod and failed miserably. Time to take a trip to the store to get some gorilla glue and snag the shower rod.
Quick Reply: DIY:Door peeling (experimental way)
