DIY Angel eyes
Old 12-09-2002, 06:30 PM
Tatewaki's Avatar
DIY Angel eyes
I'd definitely do it if I have a 02+ TL/TLS
http://john.thelgnet.com/angel/
Tatewaki
Old 12-09-2002, 06:35 PM
Beason's Avatar
how would u do that on a tl?? i think that should stay a bimmer trait
car_lost's Avatar
oh man that is awesome... and my luck... i have an extra set of clear '03 headlights that i need to open up to fix. i just might try this out.
Old 12-09-2002, 07:20 PM
USMC Butterbars
shimbo519's Avatar
that looks HOT!
Old 12-09-2002, 07:43 PM
SilverUA5's Avatar
so this will go on the highbeam part?
Old 12-09-2002, 07:52 PM
Moderator Alumnus
ArN 2000 TL's Avatar
I would like to see what it looks like...might be too noticeable during daylight...i also see drilling through the housing to run those wires right?
Old 12-10-2002, 01:45 AM
UA5-TL's Avatar
use super white pls
blue too rice
Old 12-10-2002, 02:19 PM
69tl's Avatar
looks great!
Old 12-10-2002, 02:26 PM
Flyin' and Drivin'
Comet2404's Avatar
hmmm... a little to complicated for me, but I'd like to see some pics of the installed one. Looks neat though, A+ for originality......
-Ryan
'99 SSM TL
Old 12-10-2002, 04:13 PM
Alexxx's Avatar
I might definately try that...looks easy to except I'm not sure about opening the headlight casing. Definately go with hyperwhite LEDs
Old 12-10-2002, 05:58 PM
Tatewaki's Avatar
I am thinking of doing it on my 99 TL fog hole, bending it around the contour, with white LEDs. What do you guys think how it'll look?
Tatewaki
Old 12-12-2002, 04:44 PM
mentl's Avatar
Inventive.
Old 12-12-2002, 05:06 PM
randomwalk101's Avatar
I'll definately do this if I have a 1999 - 2001 TL!
Old 12-12-2002, 06:04 PM
Tatewaki's Avatar
Now I just need to find the template I made when I meshed the fog holes...Bending circle would be easy, the fog hole will take some skill and patience...
Tatewaki
Old 12-12-2002, 06:24 PM
iNteGraz92's Avatar
where would you put the ring? it would look ok on the newer TL's since their high beam has a round shape to it.
Old 12-12-2002, 08:16 PM
hmm...true true...
Old 12-12-2002, 10:15 PM
Tatewaki's Avatar
When I get time and it gets warmner, I'll try it and see how it looks (not in the headlights)
Tatewaki
Old 12-13-2002, 02:22 PM
Alexxx's Avatar
Thumbs up
I took a look at my car (2002 model) and there is room in the highbeam housing where you can fit this, so it means that this thing wouldn't have to be exposed completely if you don't want to. I guess I would have to drill a hole in order to get the wires through and I'd probably hook up the switch to the empty spot near the dimmer. Now I'm not electrician, I take it this thing doesn't need that much juice if you hooked it up to a 9v battery. Maybe I'll bring to car to a shop to get this done....maybe Ron in NJ can do it.
Old 12-13-2002, 11:56 PM
Flyin' and Drivin'
Comet2404's Avatar
Hmm.. i always hate screwing around with electronics... but it may look good... I'm contemplating the thought of this..... I'd have to see a finished install before I decide if I like it or not.
-Ryan
'99 SSM TL
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
blacktsxwagon
10-27-2015 10:12 PM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: DIY Angel eyes
