different types of Mobil1 ...
Old Oct 25, 2008 | 05:10 PM
1st timer's Avatar
UB6IB9
I changed my engine oil last week with mobil1 5w20 super 1000 and noticed oil leaks ever since then.I'm almost positive it's the oil so I went today and bought mobil1 5w30 super syn. I will check tomorrow for oil leaks.Why does 5w20 cost 50% less than 5w30? There also regular 5w30 and 5w30 super syn,whta's the diff?
Old Oct 25, 2008 | 06:43 PM
Rajca's Avatar
wham bam thank you ma'am
synthetic oil is thinner and protects better but it will leak through small "gaps" that reg oil wouldnt.
Old Oct 25, 2008 | 06:59 PM
fsttyms1's Avatar
It shouldnt leak just because of what it is. Where is it leaking from?
Old Oct 25, 2008 | 07:20 PM
1st timer's Avatar
UB6IB9
Don't know,I wiped everything down and will check tomorrow for leaks.Isn't mobil1 synthetic only?
Old Oct 25, 2008 | 07:28 PM
1st timer's Avatar
UB6IB9
It's not the first time I use mobil1,i've been using it for the past 3 years with no problems.
Old Oct 25, 2008 | 07:43 PM
Rajca's Avatar
in the same car?
is it leaking around the middle of the engine bay, bc if it is then its most likely your rear main seal, or you just spilled some when u were willing it up.
Old Oct 25, 2008 | 08:07 PM
1st timer's Avatar
UB6IB9
Yeah the same car.What bugs me is that there was no sign of a leak prior the oil change.Will have to wait and see now that I went back to 5w30.
Old Oct 26, 2008 | 11:42 AM
01tl4tl's Avatar
do some research on what the oil numbers mean- and then go find the real source of your leak.
Mobil1 is now made with different formulas- the old good stuff--- is now called
hi mileage or extendsed use
and the new stuff with lesser quality base oil is mobil1
have to read the labels carefully on everything you buy!!
Old Oct 26, 2008 | 11:47 AM
01tl4tl's Avatar
I changed the oil on my recently aquired 20 year old motorcyle, and 50 miles later a small side o-ring type oil seal blew out.
Was it new oil caused the problem, or simply a rubber seal that had dried up and cracked during storage, then was put to use again?
Thats what it looks like, a worn seal. $3 new part- and remove some bolts to get at it.
Not some crazy internal overpressure from new oil caused yada....
like some online experts were quick to suggest~
Old Oct 26, 2008 | 03:18 PM
1st timer's Avatar
UB6IB9
Checked the car this morning and.......STILL leaking!From the middle of the engine bay,between the tranny and motor.It's engine oil by the way.
Old Oct 26, 2008 | 03:24 PM
Rajca's Avatar
your rear main seal has gone to shit. only way to replace it is to take out the trans, a lot of work for a seal that cost $7 or so dollars
Old Oct 26, 2008 | 04:29 PM
01tl4tl's Avatar
4 hours at shop labor 6 hours home labor with proper tools-
also need a big friend and heavy duty transmission jack --so its 450 pounds doesnt fall and kill you
01tl4tl's Avatar
that seals only 7 bucks??- and I was telling people 10!
Old Oct 26, 2008 | 04:30 PM
01tl4tl's Avatar
you can remove the inspection cover-2 bolts- and the oil should drip right out of there
but no way to get at it without trans removal
Old Oct 26, 2008 | 04:49 PM
Rajca's Avatar
yup $7.87 according to http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Oct 26, 2008 | 07:00 PM
1st timer's Avatar
UB6IB9
Man i'm thinking of selling the car don't need this crap right now!!!!
I want to get the 03 A-Spec. But then again i'll probably run into problems again!!
Old Oct 26, 2008 | 08:40 PM
derrick's Avatar
5w30 is short from the manufacturer ... the hurricanes stopped production of 5w30 so it will eventually be back on the shelves (well, that's what the guy at Murray's in Detroit told me)
Old Oct 26, 2008 | 09:13 PM
1st timer's Avatar
UB6IB9
Found one with 63k miles!!For 17k cnd $
Old Oct 27, 2008 | 01:05 AM
rob-2's Avatar
If you go back to 5/30 regular oil does it stop leaking?
Old Oct 27, 2008 | 07:06 AM
fsttyms1's Avatar
Its pretty common on the J32A2 so your not alone, mine does too (though im waiting till i need a new clutch before i waste my time on it). Try going back to the 5w30 which offers slightly better protection and what the motor was actually designed for
Old Oct 27, 2008 | 09:01 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
And I believe the Hi-Mileage Mobile 1 says it has seal conditioners in it, which might help perserve the seals in our older engines...if you believe what they say, anyway.
Old Oct 27, 2008 | 03:46 PM
1st timer's Avatar
UB6IB9
Its pretty common on the J32A2 so your not alone, mine does too (though im waiting till i need a new clutch before i waste my time on it). Try going back to the 5w30 which offers better protection.
I went back to 5w30 and noticed some leaking yesterday but today so far has no leaks.I hope it stoppedI called the dealer today to get a price on changing the rear main seal and quoted me 8-9hrs of labour,that's insane for a 10$ seal. 10$seal=1000$ job!!!!!!!!!!!!!
Old Oct 27, 2008 | 03:48 PM
rob-2's Avatar
If it isn't broken...
Old Oct 27, 2008 | 03:49 PM
1st timer's Avatar
UB6IB9
Does mobil 1 make non synthetic oil?? I was thinking of getting the high mileage mobil but what is considered high mileage? Mine has 80k miles.
Old Oct 27, 2008 | 06:01 PM
derrick's Avatar
Some will argue mobil1 is not a "genuine" synthetic, despite the label saying it is. (It's a matter of semantics and a court case they lost a few years back.) But if you are going on what the current agreed upon definition of synthetic oil, there is no non-synthetic version of mobil1 that I am aware of.
The high mileage mobil1 is the "old" formula of mobil1 ... which is more of a 'real' synthetic oil than the current formulation. You can use the high mileage one at any time.
Old Oct 27, 2008 | 08:59 PM
1st timer's Avatar
UB6IB9
Cool,thanks.
Old Oct 28, 2008 | 03:40 AM
01tl4tl's Avatar
03 cars have problems of their own- watch for trans warranty limits and if timing belt recall was done
Old Oct 28, 2008 | 06:32 AM
1st timer's Avatar
UB6IB9
Is there a timing belt recall for 00 TLs?
Old Oct 28, 2008 | 07:07 AM
fsttyms1's Avatar
no
Old Oct 29, 2008 | 02:16 AM
SodaLuvr's Avatar
Rear main seals only leak if the engine has been poorly maintained, according to my friend who's a master tech at an Acura dealership.
Chances are, there's nothing you can do at this point to stop the leak. 5w-30 won't make it leak slower, nor will it protect any better. You'll just have to have this repaired.
Old Oct 29, 2008 | 08:30 AM
fsttyms1's Avatar
Not all true. The J32A2 has a problem and its known by acura. But you are correct. If it is leaking there isnt any thing you can do
Old Oct 29, 2008 | 10:00 AM
phee's Avatar
I got the Shifts
is your oil drain bolt properly torqued?
Old Oct 29, 2008 | 03:07 PM
1st timer's Avatar
UB6IB9
Yes,double checked the plug and filter.
Old Oct 29, 2008 | 03:08 PM
1st timer's Avatar
UB6IB9
I maintain the car very well.The leak semms to have stopped/slow down. I'll give it some time and see.
Old Oct 29, 2008 | 03:16 PM
L3wD's Avatar
FPR pimpin'
Hey fsttyms Is there anything I can do to prevent it from leaking, so I can do it before I drop the engine in?
Old Oct 29, 2008 | 07:24 PM
Rajca's Avatar
u really cant do anything except replace it with a new one.
Old Oct 29, 2008 | 08:27 PM
1st timer's Avatar
UB6IB9
The dealer quoted me 9hrs of labour!!!!!!!!!!!
Old Oct 29, 2008 | 08:43 PM
Rajca's Avatar
yup its about 6 or so hrs to take the trans out adn put it back, and it only take a couple of min to replace the seal
Old Oct 30, 2008 | 03:54 PM
L3wD's Avatar
FPR pimpin'
No no what I meant is if theres anything to prevent it from happening
Right now i have J32A2 in my garage thats gonna be built then dropped into my TL so if there was something to fix it.. or upgraded seal or something then i'd do it now. but if not I'm still gonna change that seal before I drop the engine in
Old Oct 30, 2008 | 04:40 PM
Rajca's Avatar
changing it is the only thing u can do.
