Debadging gone wrong
2003 TL-S w/Navi NBP
Rather than hijack another post, here's one of my own. My '3.2TL' trunk emblem came off while washing my car last w/e. Instead of just sticking it back on (or sticking 'them' back on since it broke), I decided to try and clean the residue and polish for a partial debadging. Well, here are two pics of the result:
![](http://images1f.snapfish.com/232323232%7Ffp8%3C8%3Enu%3D3233%3E%3A%3C4%3E4%3C9%3EWSNRCG%3D337992%3C742339nu0mrj)
without flash
![](http://images1f.snapfish.com/232323232%7Ffp%3A89%3Enu%3D3233%3E%3A%3C4%3E4%3C9%3EWSNRCG%3D337992%3C739339nu0mrj)
Nice, huh?!? It looks like the clear coat has freakin peeled off! Any ideas?
without flash
That's after both Meguiar's Ultimate Compound, and Meguiar's ScratchX2.0, using an aggressive foam hand-held sponge and a buffing foam sponge; rubbed out with a micro-fiber towel.
I'm thinking wet-sanding or a detailing expert with an orbital buffer. Replacing the clear coat really concerns me.
Thanks for the sentiments. Yeah, I think the whole car might have been repainted, or at least a new clear coat. There is bad prep work all over the car, although the clear coat is in decent shape. I think they taped-off the emblems and sprayed clear coat around it, so when I pulled the emblems off, the clear coat around the edges came with it. They should have sprayed with no emblems on, then added them after the paint cured.
If I rebadge the emblems, there will still be an obvious outline of where the clear coat peeled off. I need to at least blend the edges of the clear coat back into the paint, THEN add the emblems. A Porter Cable buffer would be best, but I don't have that. I wonder if I could blend it by wet-sanding.
Sorry Dude but it does look like some shotty bodywork on your trunk, i can see what we call sand scratches from bondo work on your trunk i hate seeing stuff like that !!! The best thing to do is to find a good bodyshop to fix and repaint your trunk i would almost bet that its been repaired before looking at the pic you posted!
acuratl26
04-23-2020 07:30 PM
