Dealership price estimate@@@@@@
im takin the car to the dealership to most likely fix an o2 sensor....the check engine light is on all the time
anyone kno how much this shold talk
Just change the O2 sensor yourself. If you get an OEM replacement, it really is just plug and play. All you need is a wrench to remove the sensor from the bung pull out the old sensor and harness. Then just install the new one, that's it.
@ slide or die @
part price 136.xx
expect the labor to be ~ $90
Buy the sensor online for around 95after taxes, jack up the car on one side, and with an adjustable wrench, screw it out, unplug wire, screw the new one and plug the wire...BE SURE YOU PLUG THE WIRE HARD!!!
should take you 15-30min...the stock sensor will be on VERY TIGHT!
brandnewcolony
09-12-2015 10:39 AM
