Dealer Service VS ?
Dealer Service VS ?
What do you guys recommend is a subsitute for Dealer service and without losing quality of work.
I have a 99tl with 50995 miles, needed a tune up so I decided to get a full tune up (60000 mile service) Us New Yorkers because of the severe driving conditions have to baby our cars so I did my 60000 mile service early.
Now the reason for my post.
60000mile tune up cost $445
+ addit'l fuel inj. cleaning $250
Totaling $695 before tax
They gave me a discount and charged me $639.91 after tax for both.
The service At ACURA OF VALLEY STREAM is good, but could I have gotton the same type of service somewhere else without the high price.
I have checked pep boys $301.88
& Strauss $462.45 who does the same work acura does.
So if you see what I am getting at from &301.88 to $639.91.
I know you get what you pay for but damn!!!
Should I have just gone to Pep Boys or what do you guys recommend?
I have attached what work acura does in the pic.
Acura Work
26,250 Mile Service "A"
Change oil - replace with up to 5 quarts of Premium AGIP |
motor oil I
Change filter - replace with genuine Acura oil filter
Check all fluid levels
30,000 Mile Service "E"
Change oil - replace with up to 5 quarts of Premium AGIP motor oil
Rotate and balance tires, adjust tire pressure and inspect for wear
Clean and service brake calipers
Inspect brake pads
Inspect and retorque front and rear suspension
Reset timing and idle adjustments
Replace spark plugs (except platinum tip plugs)
CheckPCM, TCM, ABS, and SRS computer systems
Check and adjust valve clearances where applicable
Replace air filter
Replace fuel filter
Change transmission fluid
Drain and flush antifreeze
Drain, flush, and bleed standard braking system
Change differential oil where applicable
Oil and fuel additives
Refill all fluids
Inspect and clean distributor cap and rotor where applicable
Perform cylinder compression test
Function test anti-lock brake system
Clean engine compartment
Road test vehicle
motor oil I
Inspect brake pads
Replace air filter
Replace fuel filter
Refill all fluids
Road test vehicle
I would only trust Acura with the maintenance of our cars. Try to find another dealer that might have a lower price for the 60k service.
P.S. $250 for fuel injector cleaner?
Go to Pepboys and buy it yourself for $15-$20.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Smitty's Moral Police
I guess the question is HOW did they clean the injectors? Did they put a $6 bottle of cleaner in or did they physically clean them? And what did the competition pricing include? Either way, the dealer is usually more expensive for everything and anything
does anything happen to our warrantys, if we get the work done somewhere else or we choose not to get certain work done because we can do quite a few things ourselves @ a 10th of the price?
Concering the feul inj. They do a complete fuel inj. They hook up the fuel inj. to a machine that clean the heads. They clean the fuel lines and they add something to the gas tank.
For a complete fuel inj cleaning at pep boys is $139.
I just came from there today.
I checked the prices at all of the dealers in the NYC area and Aruca of Valley Stream is the lowest.
But no one has answered my ques.!!!!!
What do you guys recommend is a subsitute for Dealer service and without losing quality of work?
mrkingstonvi
02-22-2016 01:53 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
