Dash lights on
Could be any number of reasons. Id get the codes read. Other wise all we would be doing is guessing.
You can jump ports 8 and 13 in the OBD II with a paper clip or a wire to read codes. Turn the car to "ON" and the ABS light will flash. Make sure not to start the car, just turn it to the "ON" position. The amount of flashes signals the what the code is.
Attachment 103231
Here's what it will look like when done:
Go to this site to see what the flashes represent.
ECU AND ABS CODES HERE! - Honda-Tech
Attachment 103231
Tri State ViP Crew
thanks appreciate it the last time the TCS light stayed on was when i had the the wheel bearings done the mechanic said if i got it right the sensor wire for the TCS got damage and they replaced it and everything was good after which the shop paid for which was over 6 years ago
Tri State ViP Crew
Curious3GTL thanks but my plug was under the steering wheel panel and not under the radio but took a few minutes to find it thanks again and the flashes were
TCS 31 and 34 cant find the codes
ABS
61 - ignition voltage
11 - wheel senor (open/short to body ground/short to power) FR
are the senors hard to change thanks
ABS
front wheel sensors are pretty easy, ck out the DIY
lets us know how much they cost these days,,iirc under 50?
did you try a youtube search for eric the car guy- he seems to have one for everything!
01tl4tl (06-23-2015)
Mr.Helpful Diagram
Disregard the TCS codes focus on 11, for 61 check both ABS and TCS fuses.
Had any work done around that area ? check the connector (orange one on the shock tower by the cruise control unit) for corrosion broken wire, if nothing replace the sensor.
wd or any penetrating spray and let it sit
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
Greengecko
09-16-2015 08:19 PM
