Cutting rear bumper tabs.
Can anyone direct me to pictures of cutting the rear bumper tabs. I've looked and have not been successful in finding a good thread. I'm probably not hitting the right search criteria.
Thanks in advance. |
I cut along the red lines. It depends how much you have to cut, by the amount of rubbing you have.
sssick,
Thanks for the picture. I'll probably tackle this weekend. |
Chris,
How did you cut the Tab? What did you use? I have to somehow make my wheels fit and I need to shave the fender down a lot. Can you use a saw or something? |
I'm planning on using my Dremmel
Dremmel will work, but I used a hacksaw blade for better control. It's very soft and easy to cut.
I'll probably use a Dremel and take as much off as possible according to the wheel offset calculator the difference between a 19x8 +50 and a 19x8.5 +45 is only 11 mm on the outside. I'm betting I can atleast take off that, maybe even a little more.
Does anyone know what this infamous picture from the second post looks like casue I really want to cut those tabs...
Thanks |
