Crimestopper Rs901
Crimestopper Rs901
I was wondering if anyone has added the crimestopper rs901 remote start. It states you can add this remote start unit to any factory keyless entry or factory car alarm and start your car with your existing remote. It will also work on aftermarket car alarms and keyless entry systems. To start your car all you have to do is press the lock button on your existing remote three times or hook it up as an aux channel. Here is a list of all the features of this alarm.
*Tach or tachless mode
*timed self start mode
* Makes 3 remote start attempts
* Hood open safety (hood pin included)
* Valet mode (led included)
* programmable run time 12, 24, 36, 48 minutes
* Anti grind
* Factory alarm integration
* Idle down mode
* For automatic transmition vehicles
* programmable
If this is true, has anyone tried it and what does tach or tachless mean? Also if I put the key in the ignition it will start continue to run? Also, if someone tries to shift the key in gear without the key, will the car shutdown? Need some information before I invest in this remote start.
* Anti grind
* Idle down mode
* programmable
Petie
10-18-2006 06:49 PM
97AcuraCL
03-15-2006 06:55 PM
