Crankshaft Pulley Timing Marks
Hello,
I have a 1999 Acura TL and i would like to know if anyone know what marks on the crankshaft pulley do i use to line up "tdc"? When i look at the crankshaft pulley i see a single yellow/white mark and three other mark's? Thank's
You don't use the Crankshaft to find the TDC for each Cylinder.
In the Camshaft Plastic Cover there is a small rubber gate you put aside to see the alignment Arrow for the Camshaft and the Plastic Cover, Each Arrow has a specific number which designates the TDC for that Cylinder.
There should only be 1 single mark/groove on the crank pulley, it should be a single grove cut into the pulley. That is what needs to line up with the crank mark on the cover
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
