Could anyone give me any tips on installing an Upper Strut Bar
i got my upper strut bar (chrome :wow: ) and i havent installed it yet cause the thing is too damn hard to put in. Anyways, I was just wondering if anyone out there has some advice on how I can get this thing over both strut towers without taking it to a shop and getting charged for something I should be able to do. The tie bar is about .5 inches too long. Any suggestions would be appreciated.
Originally posted by CarFreak
Hey, werent u supposed to sell your car? I'll gladly take the strut bar odd your hands when time comes to sell.
Originally posted by eggbert
Jack the car up slightly on one side to get the bolts to match up.
I installed the Neuspeed (only mod I have)
actually if you want to get the most flex you should jack up the car from the front (middle). my car was like 1/4" long, so i had to do that to flex the car enough to put the bar in
i don't even know how i am going to take the bar out anymore @_@
Originally posted by Yaron2
WTF.............. just hire someone to install it for you .... sounds like you haven't the 1st clue
Originally posted by nameeri
Will this work?? The strut bar is too long, I would think that jacking the car up on one side would make this problem even worse. I could see doing this if it were too short.??
I got one hole started on each side... used a soft mallet to help it along..... turn the bolts to tighten down... adjust the jack up and down to help some more.
Just takes some fiddling. At one point it DID seem like it would never fit.
Whats a good jackpoint in the middle of the car? I dont want to screw anything up when i do this. Thanks guys...
ok, lie down in front of the car, right from the middle (the grill area). use your hand to feel and gradually move from outside to inside. initially you will feel some plaster, pretty loose. that's the flap for avoiding dust and stuff. after that, you will come to a hard metal. that's where you jack the car up
Ill try that on saturday. I want to get this darn thing on already and take some pics
Actually it helped a bit. I remember jacking the left side... the right side is still firm on the ground. Jacking up the left side up high brought the left father away from the right. The car flexes a good deal without the brace.
Ill try this out on Saturday too. Ill take plenty of pics after the things is on and all polished up!!
wut i did was jack the car up from one side, loosen the stock strut bar a lil, then get two people, and use as much force as u can to force the strut bar into place.
cycdaniel
12-17-2019 10:58 AM
marcelft
07-10-2018 06:17 PM
acurajj
02-14-2016 02:28 PM
