Cooler running thermostat for a 2000 TL
Old 03-01-2004, 12:48 PM
juniel's Avatar
Greetings to all,
Has anyone replaced their OEM thermostat for the engine to run a little cooler
than the original 78 degrees C ?
If so, I'd like your observations on how the engine runs w a cooler thermostat.
Thanks.
juniel
Old 03-01-2004, 01:08 PM
Type S Lady's Avatar
Hey, I just replaced mine with a Mugen thermostat and fan switch. I did it because other members running with SC's recommened it. I didn't notice it running any different but here's Mugen's write up:
This thermostat has the operating temperature set lower than normal. It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving. The use of a flow-control-type valve prevents hunting, thereby achieving rapid stabilization of the water temperature (the engine warms up within a short period). Operating temperature: 68°C (STD.: 76~80°C) Full-throttle acceleration temperature: 81°C (STD.: 90°C)
And the fan switch: Activates cooling fan at 80°C instead of the stock 93°C. Requires use of Mugen low-temp thermostat.
These stats are for the Prelude but you get the idea. Hope it helps.
Old 03-01-2004, 06:26 PM
Boomer SOONER
ou sig's Avatar
The quote from Mugen says it all "It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving."
Do you plan on doing circuit driving? Probably not, so I wouldnt even worry about it at all. It may be necessary if you mod the hell out of your car and plan on driving it like that...
Old 03-01-2004, 11:22 PM
Incubus's Avatar
Feel the rhythm, feel the rhyme, get on up, it's bobsled time...COOL RUNNINGS!!!
I saw "cooler running" in the title and I immediately thought of that movie about the Jamaican Bobsled team from 1988. That's good stuff.
By the way, I'm new here.
Old 03-08-2004, 11:50 AM
juniel's Avatar
Mugen thermostat
Type S Lady,
Appreciate your reply.
A few more questions.
1. Your temperature gauge, where is the needle positioned now with the
Mugen thermostat installed.
2.Where can I purchase one and for how much did you pay for it-
thermostat and the fan switch.
Thank you again.
juniel
ghuns
09-16-2015 04:26 PM
09-14-2015 10:09 PM
Mike Bertram
09-10-2015 09:27 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: Cooler running thermostat for a 2000 TL
