Coolant mysteriously disappeared
Hey Ziners, I have a concerning matter that I can't seem to figure out.
Info on the car: 2000 TL with 201,400 miles on the clock. Sitting since August. While I'm away at University, I have my TL stored in my garage. It hasn't been driven since August. When I put it away, I checked all fluids, everything was fine. I came home today, and checked everything. I was going to run it and drive it around the block, but the overflow bottle is empty, and the radiator doesn't seem to have anything in it. My first instinct was to re-check the oil to see if it had coolant. It looks clean- it didn't look like chocolate milk. There is no puddle, no anything. The car had coolant, but where could it have gone? None in the oil. I started the car and ran it for 15 seconds, so it wasn't in the cylinders. What do I do? |
I would look at the oil real well again after you ran the engine a bit, that might have got the water stirred up, otherwise, without the engine running for so long, the oil would been floating on top of the water. And it is unlikely all or even most of the coolant could have gone into the oil system without overflowing somewhere.
I would fill/top off the radiator and see just how much fluid it takes to bring it back to correct level. Make sure your heater valve is turned all the way open (hot). Then look for leaks. If none seen, start the car & run and look for leaks, recheck oil, etc. |
First thing i would do is look at the ground for any staining or water stain type of spots. If none, then i would drain the oil BEFORE driving or starting the engine just to make sure its not in there unless you can be certain that there is none on the dipstick or the level isnt higher than it should be. The oil wont be milky from it draining into it. The motor needs to be running and mixing the 2 together to become that way.
Hey Yikes, nothing really actually disappears......it's only an illusion !
Look for any clues for an external leak. If you parked the car a few months ago and everything was in good working order at that time, than consider having the coolant system pressure checked. These guys gave you the lowdown about [I]"coolant in the oil"[I] and the potential of a blown head gasket, but take a step back in time....as this had to be happening prior to parking the car ! Any other overheating situation or low coolant or just plain negligence ? |
punk kids drained radiator valve while it was parked?
stranded motorist did same when they needed coolant? res bottle cap--hose attached firmly? rad cap- seal and spring are in good condition? rad seams- signs of white or green? |
Thanks to everyone who responded.
Originally Posted by 3.2TLc
(Post 14174141)
Originally Posted by 01tl4tl
(Post 14174286)
stranded motorist did same when they needed coolant? res bottle cap--hose attached firmly? rad cap- seal and spring are in good condition? rad seams- signs of white or green? I couldn't find any external leaks, but I can't 100% rule out that the coolant didn't run past a bad head gasket and into the oil pan. I only ran the car for about 15 seconds, and rechecked the oil, and it didn't look milky or odd, but then again that may not have been enough time to mix things up. I'll have to drain the oil from it, refill the coolant system and bleed it. I'll let you know of the results. |
seafoam for storage is fog it --so it dies and no drive
that coats important parts revving in driveway tends to foul plugs but not blow head gaskets etc oil level--is it suddenly above full??? fuller than you left it? locked most of the time= allows an opening for someone desperate enough--to remove your coolant and install in their ride! would not be the first time |
when you fill it with water/coolant mix now- what does it do
leak out? runs ok? parts store can test rad cap for you make sure heater is on full hot and cabin fan running to get all the air bubbles out while following the owner book method for burping system |
(Post 14175609)
leak out? runs ok? parts store can test rad cap for you Update: before I left back for school I filled and bled the system. Everything seems to be okay now, I didn't notice any leaks. I'll have to check back in 18 days when I come home for winter break. As for the oil level, it didn't seem higher than I remember; certainly not enough to justify almost 100% of the radiator and overflow to run into the oil pan.
(Post 14175605)
as well as clogged egr and dirty iacv,,,do those when you get home
rad cap can face either way,,,someone ckd or replaced coolant at some point- as you suspect was the wp replaced with tbelt at 105? |
