Converting TLS Fog light to HID 6000K!!!
Old 01-07-2002 | 09:03 PM
  #41
Las Vegas TLS's Avatar
When I look at the foglights there is a black ring around the halogen bulb and the headlights have a reflector so the xenon reflects back towards the reflector. When you remove the old halogen bulb and install the new xenon bulb instead do you try to modify the fogs buy removing the black ring? I think the premise is a little different when you compare the both. I think when you see the xenon light what you are seeing is reflected light. When you see the halogen light you are seeing both the bulb light and reflected light.
What did you do?
Also, did you hook up relays or just plugged into the old outputs for you halogen bulbs?
Does it seem that oncoming traffic is blinded?
Old 01-07-2002 | 09:25 PM
  #42
TypeS_Monster's Avatar
Originally posted by Las Vegas TLS When I look at the foglights there is a black ring around the halogen bulb and the headlights have a reflector so the xenon reflects back towards the reflector. When you remove the old halogen bulb and install the new xenon bulb instead do you try to modify the fogs buy removing the black ring?
ANSWER: NO you don't have to move anything in the light house except old halogen light bulb. it is like plug and play. take out the halogen and plug in the xenon light bulb. that's all!
ANSWER: just look at the pic that I attached and you don't need anything except the xenon light bulb and the ballast. you insert the xenon light bulb, connect the wires to ballast and from ballast there is 2 wires(black and red) that sticks out and that goes into the old outputs for you halogen.
Previous pictures from this topic has a good picture where it shows that has nice cut line light output. in other word it will not blind oncoming traffic. there's NO GLARE from the fog light!
Old 01-30-2002 | 07:32 PM
  #43
fuggedaboutid's Avatar
Originally posted by TypeS_Monster
for those of you who has some money to spend: UPGRADE YOUR FOG TO HID!. DO not spend money on cheap bulbs that look like HID. I wish our (at least 2002) TL and TL-S fog has HID in it. Anyway, you WILL NOT regret on this HID conversion. I bought philips 6000K called "ultinon" conversion for 9006 bulbs.
How much did it cost you?
Old 01-30-2002 | 10:30 PM
  #44
asiankidd's Avatar
if anyone is interested i can get the philips 4500'k true HID brand new for 450.00 this will perfectly match anyones stock HID low beam, and is street legal, the philips is straight plug and play just like the 6000k ones but just arent the 6000k bulbs, if anyone is interested email me at jlerd@hotmail.com
lates guys
Old 01-31-2002 | 03:16 PM
  #45
NighthawkBlack's Avatar
I was wondering from your pics if you took the red and black wire leads from the ballest and connected then directly to the stock wires that powered the 9006 bulbs that used to be in your TLS. How dod you wire that part?
Old 01-31-2002 | 03:23 PM
  #46
bobatimez's Avatar
its nice to see you guys catching up finally...
Old 01-31-2002 | 03:42 PM
  #47
NighthawkBlack: yes you are correct on that. take the red and black wire from Ballast and connect directly to the stock wires. that's all!!! very easy!
Old 01-31-2002 | 03:53 PM
  #48
I have a question for all of you. Please do answer...
The cost for HID kits (500-600US), how much profit are the sellers making?
In Canada, I can get Philips HID 6000k from 3 different shops for 500cdn = 330US.
I rather shocked, though that the HID kits (2 ballasts, 2 HID bulbs) costs so much. Anyone agree? I just can't justify having the HID prices fall another 50% while I or someone else buys a set in the US or Canada.
Old 01-31-2002 | 03:58 PM
  #49
InspireS's Avatar
Where in Canada can you get HIDs for that price? Can you send me some info?
Thanks,
InspireS
Old 01-31-2002 | 04:02 PM
  #50
So those wiring harnesses with fuse and relay can be substittuted with stock ones? The reason I sak is that I have a stock OEM add on wiring setup from the Honda Inspire and their H1 Fogs and was thinking about doing this conversion even though the H1 Phillips kit costs almost $200 more than the 9006 TLS setup. So you haven't had problembs and they start up and warm like normal using the OEM Acura wiring?
Old 01-31-2002 | 04:05 PM
  #51
By the way your ballasts are made by Hella? The pictures on Autolamps. com show Phillips Ballasts.
Old 01-31-2002 | 04:09 PM
  #52
WHAT???!!!
that's great price!
$330!!!!
damn it!
what's going on here?
for a set of philips Ultinon 6000k, the lowest price that I know in US is $525.
hey Canadian man hook us up!
Old 01-31-2002 | 04:22 PM
  #53
yeap, it works just like that! I was afraid it might not work but I took a chance. whew... when that thing light up, I was happy! anyway, yeah my ballast is made by Hella and I didn't get that set from Autolamps. By the time I purchase the set they were selling Philips 6000K set for $800!!! So I order the set from HID4less for $600 and that was 2 month ago. And now the price has been dropped to.... $575. dang it! oh well.... I'm still happy though... when the both main beam and the fog lights on... IT IS BRIGHT! (e.g. reflection from front car bumper)
Anyway, the both Hella and philips ballast are made from Germany. i think both of them are pretty good. It doesn't matter what kind of ballast you get. the only matter is the light bulb. get the philips made only!
Old 01-31-2002 | 04:41 PM
  #54
I agree it doesn't matter. I was just confused with your pic and the one on autolamps. com because of the wiring. Thanks for the info.
Old 01-31-2002 | 04:43 PM
  #55
Crzy Acura's Avatar
SOOO how much for just the ballast ? I really would like to use my stock HID bulbs for the fogs.
Old 01-31-2002 | 04:59 PM
  #56
I dont think you can use the regular bulbs form your low beams beacuse of the base of the bulb. These kits have the Phillips bulbs mounted on new bases that coincide with 9006 or H1 in my case.
Look at the site autolamps from the first page post
Old 01-31-2002 | 07:31 PM
  #57
Wink
Okay, I'll try my best to give the best possible info .
1. Speedtech - contact Sherman and ask for the TAC pricing. it's $525 cdn I believe these are made by Philips. ph# (416) 293-6887
http://www.speedtechauto.com
e-mail: info@speedtechauto.com
2. Toronto Accord Club (they are doing an HID groupbuy) http://www.torontoaccords.com/forums...pic.php?t=2543
Old 02-01-2002 | 06:15 PM
  #58
Okay...I just bought a new 2002 TLS w/Navi yesterday and I'm geeked about adding some better fog lights. (Actually, there's a lot of things I want to do) I'm interested in the 6000k, but is that too much? Should I look at Asiankidd's 4500k that he's selling to better match my factory lowbeams? Need some help with this.
I'm new to the ACURA TL-S world, and this is my first post. So give me a break.
InFaMouSLink
10-27-2015 07:51 PM
sockr1
10-01-2015 02:31 AM
ellisd03tls
09-08-2015 05:17 PM
cruisingnycfl
09-02-2015 01:11 PM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
Quick Reply: Converting TLS Fog light to HID 6000K!!!
