Convert 2001 auto to manny
If im not mistaken... You are wondering if it is possible to swap your auto transmission from you 01 TL to a 6spd manual transmission?? To answer your question "is it possible?" Yes it's possible, check the DIY thread on doing a 6spd swap. There's a bunch of threads on doing 6spd swaps for Second Gen TL's. Please be more specific on what you're inquiring about.
My bad, I was under the impression that the type-S were manuals. I couldn't find any threads with enough information. Would it be possible to use a manual transmission from either an Accord or Civic to do the conversion?
we use the automatic from an accord to replace our automatic.
for a 6 speed with LSD (limited slip diff) you want to grab a unit from a CL-S
See the threads by fsttyms1, near top of thread list, on the conversion his car rocks~
Smart use of the manual shift portion of our trans (Tiptronic or sport shift) should be enough to stimulate your racer urges while not wearing out a clutch~ or for us older folks, a hip!
Just watch the high rpm downshifts into 3 and 2nd gears, that heats the clutches and is the reason for clutch failure!
Pham Alvan
03-16-2016 09:17 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
