Are Comptech Sways really better and worth it?
Lead Footed
Okay, maybe I missed it, but can someone splain why go with the Comptech sways based on the data below?
I'd have to assume that Comptech uses a special alloy that provides greater stability in spite of its equal or slightly smaller size.
That however is not immediately obvious from the data on the TL site.
ACURA OE Stabilizer Bars Specs
Front: 1.07 in./ 0.18 in. (1 1/14")
(27.4 mm) diameter x (4.5 mm) wall thickness
Rear: 0.75in. (3/4") solid rears, 19.0 mm
Comptech Stabilizer Bar Specs
Front: 1 1/16 tubular front (27mm)
Rear:
7/8" solid rears (22mm)
RUF
Rear:
RUF
Having Fun?
Also, don't forget the bushings make a big difference.
A good quote taken from Road Rage: ( Thread )
The Comptech bushings are polyurethane - you can adapt the factory bushings, but remember that the stiffer poly bushing will not deflect as much, and will give a sharper, more precise and consistent turn in - that is why racers use them, since a solid bushing will not change the suspension attitude fractionally over a short interval, leading to possible attitude change in mid-radius of a turn.
-copland007
-copland007
Ruf87,
The best advise I can give you is for you to hook up with someone who has the same car as you (preferably with the same setup) and will let you try (drive) their car. This is what I did before buying mine and I WAS HOKKED.
No amount of us telling you how good the ride is will help until you see/feel for yourself.
If you still want my opnion do a search.
What's the wall thickness of the front for COMPTECHS... wont that might make a difference ? YES/NO
Originally posted by KJ32
Do you have to periodically add silicon grease to avoid squeaking? I have heard some ride with lots of noise when the car bounces on the road.
Ruf87,
I'd be happy to let you try my TLS out. I took some guys out at one of our meets at the coffee shop at Park and Coit. I guess you weren't in on that ride. They felt the difference! PM me if you would like to ride.
--PlanoTLS--
--PlanoTLS--
Hey PlanoTLS
Let me know when you North Dallas guys are getting together again as I am up in McKinney and, being a newbie at this stuff, I would like to see what everyone is driving, how their mods look, and what they think of the performance.
I have the Comptech springs and swaybars on order--too bad Comptech is "experiencing a delay" on the sways until the end of the month.
InfernoTLS
InfernoTLS
Lead Footed
InfernoTLS and PlanoTLS -
Check out the CL Forum regularly. That's where we do most of the meet coordination.
We just had one a few weeks ago. And had a great time. 15+ showed up. We went cart racing afterwards.
Matter of fact, we are looking at trying to get one in for the fall down in Ennis.
RUF
RUF
Ruf87
Thanks for the heads up. I will watch the CL list--I definately want to make the Ennis trip.
Cheers
Soccer fans: Dallas Burn playoff game vs Colorado Rapids
Wednesday night at the Cotton Bowl
Cheers
Lead Footed
Originally posted by InfernoTLS
Ruf87
Cheers
Ruf87
Cheers
I've been coaching youth soccer for the past few years. And been a fan since the early 70s.
RUF
Hey Ruf, how have you been?
The CompTech rear sway is thicker, you can see the difference if you put them side by side. The front bar has a thicker wall than OEM. They are great, I would recommend them along with a upper strut from Neuspeed. The upper strut make steering "tighter" and more precise with less play.
Lead Footed
How about you? Still burning rubber?
I'm still looking to take a few runs at a GS400. Especially now that I have a fresh set of tires.
And thanks for the words of encouragement and upper strut tip.
RUF the GS400 slayer . . . I hope.
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
