Compression
Compression
We intend to buy an Acura TL tomorrow. Upon passing our inspection and test drive we are going to run a compression check...What kind of numbers should we expect from the compression gauge? this is not a TYPE S motor, just a regular 3.2
Thanks for any input!
We won't buy a tired engine
I got the Shifts
3,210 cc 3.2 liters 6 V front transverse engine with 89 mm bore, 86 mm stroke, 9.8 compression ratio, light alloy block, light alloy head, overhead cam, variable valve timing/camshaft and four valves per cylinder
- Premium unleaded fuel
- Fuel economy EPA highway (l/100km): 8.7
- Multi-point injection fuel system
- 65 liter fuel tank
- Power: 168 kW , 225 HP @ 5,500 rpm; 216 ft lb , 293 Nm @ 5,000 rpm
That info does not really answer his question...
I just did a google search, fraid I cannot answer it. I think they should be around 160 PSI. Am sure someone here knows what PSI they should be at.
I tried that too...
No answer on Google...yes you are right I want the PSI...I am going to check the compression so I don't get me a sleepy motor...after all it does have 144K on it...Thanks and if anyone else knows for sure...PLEASE POST...I searched the forum first and couldn't find it...here either...
From the manual
Above 930kPa (9.5kgf/cm.2, 135 psi)-200rpm
Maximum variation
Within 200kPa (2.0 kgf/cm.2, 28psi)
Maximum variation
Thanks - Forum Members RULE
I just came from the STEALER (to ask this very question) and he said all his mechanics were too busy to talk with me...what happened to ACURA? When I bought my Integra in 87 (long gone) the service department was so very helpful and would do anything for you. Now this guy practically blows me off when I tell him I am buying a used car and need some advice...Well, I will do ALL the service on the Acura...except the safety recalls and the warranty claim on the tranny - if I need it. But other than that those guys will NEVER touch my sons car...
So I should expect between 135-144 with a max vairation of 25psi I am pretty confident in the motor at least posting those numbers, I will update this thread after I pull the numbers...
Thanks again!
Ya I am gonna get a manual for this car...which one is best?
Thanks again!
Yes those #s are from the factory service manual. Stick within those specs. (mine at 200k was right at factory #s. If it was maintained before it should be good.
Helms manual is the best.
Thanks...
Getting close to the hour when we take the trip...
If anyone can tell me how do I know the Difference between the 2 white colors? I guess there is a Pearl White and a (SP) Trafetta White? Don't say look at the car, because I am not sure I'd know the difference if I saw it...
Also, From what I get from the Autotraderonline site there are 2 different trim levels, anyone can tell me how to differentiate?
Arigato Goziamus (Thank you in Japanese)
One has pearl in it one doesnt ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Open the drivers door. There is a little sticker on the jamb.
This is the color code that will be on the sticker
NH-578 Taffeta White
NH-603P White Diamond Pearl
Got It
Well,
My son today purchased the Diamond Pearl White 99 Acura TL, it has 140K on it and pulled compression readings of 212,210,212,209,210, 208 (these numbers were considerably higher than what forum members told me I should pull - but hey they were better)...I was able to talk the guy down an additional $250 so my son got it for $5850. Has some surface wear as one would expect...
The guy was really cool, we used his 'shop' to seafoam the crankcase, drain the old oil, fill it with ROYAL PURPLE, Put in NGK Iridium plugs, and add the K&N air filter for the trip home...We went to the local Shell station Filled it with the 93 Octane Shell Super V, and added some TECHRON to the tank.
My son brought it home and SMOKED me repeatedly in the AVENGER
He cleaned and vacuumed the interior, and bought a water pump, timing belt, and a host of other accessories that I will put in tomorrow...
He has a really beautiful ride...thanks to everyone who contributed to this wonderful purchase...I am proud of him he really did it all on his own.
Originally Posted by Adrenalin540
Well,
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Originally Posted by ChrisQ1980
Post some pics of the car, and have him join the forum. Nice find and a great deal on a good car.
1fatcrxnem1
22
06-01-2018 01:23 AM
