Clunking on front end???
Old 01-31-2003, 09:06 PM
nycvr6's Avatar
I hear a clunking under the hood of my 2002 TL-S when i hit bumps. You can also hear it when i start the car up a bit. It isnt mounts because the motor feels solid. I am pretty mechanically inclined so i would pick out something obvious pretty quickly. Looking for some help or maybe similar experiences. Keep in mind the car is bone stock.
Also, if anyone knows how much it costs to get a copy of the factory key and alarm, i would appreciate that info as well. Thanks in advance for any help.
Justin
Old 02-01-2003, 07:22 AM
typeR's Avatar
i have it too, try backing up with a little more gas than usual...is it worse? i think mine is the rear motor mount and im going to the dealer tuesday or wednesday
Old 02-01-2003, 11:30 AM
nycvr6's Avatar
No mine doesnt do it at all when backing up. Sometimes when turning the wheel and accelerating, usually on bumps, and when you start the car you can hear it clunking a little for a second when the motor vibrates when it first starts. Keep me posted anyway. Thanks
Old 02-01-2003, 12:13 PM
Gilgamesh's Avatar
Its about 85~120 bucks for the key and FOB something like that, depends on the dealer, they need your VIN to copy the key cause of that immobilzer chip.
Old 02-01-2003, 03:19 PM
nycvr6's Avatar
Thanks...
Anyone else on my clunking issue?
Old 02-01-2003, 03:32 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Could be that the OEM sway bar bushings or end links need to be tightened. I had the same problem in the rear with my Comptech sways. I know you're stock, but have Acura look into it.
Old 02-01-2003, 03:39 PM
On the way!
fla-tls's Avatar
I also have a clunking sound. It happens when I mildly get on or off the gas at speeds below 40. I thought it might be brake pads, but I'm not sure. I'll have the dealership look at it when I take it in for a tire change (but that may be weeks).
Old 02-02-2003, 04:52 PM
nycvr6's Avatar
Thanks all! Keep me posted if anyone has any updates, im gonna bring mine in this week hopefully so ill let you all know what the outcome is.
Old 02-03-2003, 10:41 AM
Mr Zipps's Avatar
I have a *clinking noise* only when im slightly on the gas or under 25 mph. Im taking my car in to get that checked on Feb. 18th so I will let everyone know what it is.
Mr
03 ABP TL-S
New Jersey
Mr_@yahoo.com
02tljj
09-11-2015 12:37 PM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Clunking on front end???
