clear headlights?
You don't actually "break the plastic", the headlight is sealed by glue or silicone...what u do is heat the silicone or glue till it starts to melt and then take apart the headlights. It's actually alittle more complicated then just that...
Here's my cleared headlights.
![](http://pirate.shu.edu/~chansing/meets/shoremeet/joeyclearlit.jpg)
And Blackshadow's
And Blackshadow's
![](http://pirate.shu.edu/~chansing/meets/shoremeet/bsneon.jpg)
Its really hard to do...if you don't properly reseal the headlights, water vapor will get in and wreak havoc with your HIDs. StreetEffectz does it for 125 I believe...or you can just put a sticker over it...forgot who did that though
anyone know a place in NY that i could get it done and does anyone know what that blue light is across Blackshadow's
highbeam lights (look above) i think that is hot
-amit
-amit
That "blue shadow" across blackshadows high beam is the reflection off his hyperwhite 9005 bulbs. That's what it looks like as the hyperwhite type bulbs are actually coated blue. It glows white when on..much whiter than stock bulbs.
Peach Tea
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Bioyuki, Where is Streeteffectz located? I am looking for a place to do mine. If they do them, are they gaurenteed not to be goldfish lights? What kind of sticker did the person put on theirs? Im sure that will not be hard and expensive. I am looking for any way to get rid of the ugly amber reflectors. THANKS for any info.
That is not the reflection off the hyperwhite 9005 bulbs, if u look closely, he put a mini neon tube in this highbeam housing
BlingBling INSPIRE 32V
Iselin, NJ
Here is Do it for yourself for Clearing H/L.
¢Ñ Clearing H/L ¢Ð
¢Ñ Clearing H/L ¢Ð
"That is not the reflection off the hyperwhite 9005 bulbs, if u look closely, he put a mini neon tube in this highbeam housing"
AcuraTL,
Didn't notice it! Thanks for pointing it out
AcuraTL,
-amit
-amit
O.G.
Originally posted by bdimc2001
that's right guys that blue light across Blackshadow's TL is a neon light and not a reflection of his high beam bulbs...
do it yourself, !
It's extremely easy to do. The hardest part is getting the old silicone off. If you do that patiently then you will have no problem resealing it. I've done about 8 pairs including CL's, TL's and 02 TL's as well. Very simple and I'm the most mechanically handicapped person you will meet. I would help you since I'm in the nyc area, but I am currently up at school in upstate NY. If you would like any info, I can do this for a fee also, but mot looking to start a "business" Email if you need help or advice but like i said again..its relatively easy.
Jeremy
Jeremy
Ex-Acura Die Hard Veteran
Re: clear headlights?
Originally posted by MIKESTL
I own a 2000tl i have clear tailights from the 2002 type s now i want to clear my headlights any ideas? thanks mike without breaking the plastic?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
You talking stock 02s right? If not, pic?
Dave
