Cleaned the EGR and IACV
just throwing a guess out, but what about the airfilter? How long ago did you change it? What gas have you been using? Also what type of Oil? Did you put seafoam though a vacum line, gas and/or oil?
Double checked the vac line, A ok.
Filter KN filter just cleaned it out. Also had a AEM intake.
Changed oil to Mobil 1 with fram Extended guard 1k miles ago
the only gas i use is Shell V power
Once a month a can of seafoam in gas tank and every 3 month through the vac line.
u messed up the IAC valve.
it is not supposed to get wet.
did you remove the iac valve before cleaning.
it has a little motor in it.
i bet a buck it's the IAC valve.
replace it.
replace it.
08 Civic SI
Originally Posted by dnd2984
Yes I took off. Also I only cleaned everything with throttle body cleaner. No water.
replace it.
replace it.
wouldnt messing the valve up cause the check engine. and also isnt there always coolant circulating through there anyways.
ok i did a search on other people with idle problems. I seen a lot bad coil threads. Now my question with a bad coil wouldnt the idle be rough enough to throw a CEL. I feel vibration through the seats and steering only. And sometimes its smooth and other times it gets rough, especially with the AC on.
And no coolant doesnt run through the IAC. It runs Through the Throttle Body in coolant passages. Not the IAC
I went ahead and took everything apart today. I am at home and since there is a garage I can really get the cleaning done, and also I decieded on ekeeping the Theroblocks and intalling them.
Going to clean the hell out of everything including the throttle body and all.
OK so 3 to 4 hours total, with 9 cans of throttle body cleaner, My car does feel smoother. I took a tooth brush and cleaned the throttle body. I also instaled the Thermoblocks. So far all is good, but the idle is not the smoothest but better. Anyways the TL is going to be staying at home all week, so I will be drivnig the TSX around.
I hate this Mod-bug that keeps biting.
Have you reset the ECU and done the Re-Learn procedure?
dnd
I would suggest checking the amout of oil you put on the air filter - its easy to over apply- the can does 5 recharges!
And respray the throttle body just in case it pulled some excess oil from the filter- stranger things have happened.
Even new parts fail- its worth looking at the plugs to get a reading
On my TL I replaced the seafoam vac line- it was slightly swollen where it gets dipped in the can. Even taking it loose once can cause a loose seal at the plastic fitting- easy to replace hose with the engine cover off. Then the old school test for vac leaks with a can of carb cleaner- spray suspected connection and listen for idle speed change- if it does, you found a leak
Good Luck
Good Luck
Originally Posted by 01tl4tl
dnd
Good Luck
Good Luck
I checked the vac line and it looks fine visually. I am so glad I cleaned everything at home. Acura was going to charge me $300 for just cleaning.
BUT i do think the part of the vac line that I use to sea foam might be a lil looser.
visually fine hahahahahahahahah
Spend 2 bucks and replace the suspect line first!
Originally Posted by dro_15
can anyone hook me up with the link to clean out the EGR... thanks
Originally Posted by AgenaBluTL-S
what is the EGR ?
well if you have done every thing we have said maybe its time for a professional (dealer) to look at it.
Its possible 1 plug is bad, or not gapped correctly. Did you double check the gap of each one before install? Maybe buy 1 new plug and 1 coil pack and go 1 cyl at a time and replace both plug and coil and start teh car to see if it makes a difference. If not remove and move to the next cyl.
Originally Posted by Tom Blasing
Or just disconnect the primary lead to each cyl and see if the rough idle gets worse.
Originally Posted by PenguinQX
Sorry for the stupid Q, but what's considered "rough idle"?
Patience is a virtue....
so would you suggested me to clean the egr and the throttle body just got my car its a 02 tl-s with 33k original miles? what should I do for my first maintainace thanks
Yea but that may make it even worse and harder to tell which it is. If its a slight vibration and not throwing a missfire code it may be better to just do the one at a time and see if it smooths it out.
It's the same as your dentist finding a "dead" tooth with an electrical shock. If you don't jump, there's a problem.
I did say to reconnect the leads to the cyl that DOES change the idle. I'm not saying to disconnect the leads and LEAVE them disconnected and go on to the next cyl. That would be ludicrous.
I would start out with one NEW plug and coil gapped properly and work my way around to see if that makes a difference.
