CL vs TL 6 Speed
Unregistered Member
CL vs TL 6 Speed
This summer I'll be doing the swap over to a manual. I was looking through car-part.com, and it's slim pickings for a low mileage tranny.
I was deciding between the CL and the 3G TL manual tranny. Are there any differences between the two? I plan on using richie's module if that makes any difference.
From what I understand, they both have LSD and will bolt right up. Is one superior in any way, or are they pretty much identical?
I cant answer that.. but-
go to your local auto dismantler (junkyard)
tell them what you are doing and what you want
If it doesnt come into them, the industry hotline (like nextel) will find one for you
and get it to their or your door
talk to kris about which way to go
Unregistered Member
If I can't get a RV6 module, I won't be able to do the conversion =[
I think CL tranny is little harder to find an may cost more.
For TL it much easier found an should cost alot less then CL. Only different is where peg needed be re weld to far left like CL is.
Unregistered Member
No moonroof, no abs, no air bags. I understand that it is possible to get those to work, but if you couldn't do it, I'm not gonna try.
Unregistered Member
It's much easier to PM Richie on V6 forum an last i check he still selling them. I know someone got module from him about month ago
an he got back with me within 2 days
I'm using an 04 TL 6mt. Only problem I've heard about the early 3g tl trannys was them popping out of 3rd gear sometimes. I believe people who had the issue would switch to GM syncromesh trans fluid and that solved the problem. I have NEVER experienced a 3rd gear pop out with mine and I'm just using honda's manual trans fluid. You'll save quite a bit of cash getting a 3g trans instead of getting one from a cl.
I could have gotten them to work, ( i did get the moon roof to work) ABS i knew i was removing so i didnt bother, air bags were a simple rewire. I was in a hurry at the point i put it together as i NEEDED the car as mine had been down for months and i was tired of renting cars. Having all the parts the swap and wiring could be done in a weekend where every thing works.
it is possible to use an 05 TL 6spd trans with swapping over to a cls6 engine harness & ecu.. instead of getting the richie module? im building rebuild an 02 tls motor on the side and plan on swapping it into my 2000 tl-p. any info is appreciated thanks
Unregistered Member
It is important that you get the CL-S6 engine. Alternatively, you could convert the 02 TL-S engine into a CL-S6 engine by changing some things.
Look into Fatty's build in the DIY section.
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sep 25, 2015 06:14 PM
