Cheap Ball Joints in North Jersey, 03 tl-s
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Anybody know anywhere that does good work but doesnt over charge....need to get the front right upper ball joint done on a 2003 acura Tl - Type S
128K Miles, Owned the car for about a year
UB6IB9
I dont think so but is pretty straight forward.
1.-Took off Wheel
2.-Remove Rotor + Caliper (This is Just to Remove Weight of the Knuckle)
3.-Remove Knuckle Pin in the OEM Ball Joint + Bolt.
4.-Use a Ball Joint compressor to remove OEM Ball Joint.
5.-Reverse Procedure
X.- Forgot you need to remove the Lower Strut assembly Bolt or Tops its needed to lower the knuckle or it will stay in place once you Undo the #3 you need to lower the Knuckle so you can take it out of the Ball joint.
Hope that Helps!
1.-Took off Wheel
Hope that Helps!
Last edited by Skirmich; 03-17-2012 at 02:10 PM. Reason: OOPS Forgot Strut Assembly!
No, with the proper tool....removing the control arm is not necessary. You can "loan" this tool from most parts stores, by paying a deposit. The top BJ is much easier than the lower to replace. The "Moog" is a quality product and has a grease fitting.
MetalGearTypeS
08-29-2016 08:28 PM
