Changing the oil yourself?
Old 10-23-2003, 08:18 PM
thejavagod's Avatar
Who does their own oil and filter changes? How difficult is it?
Old 10-23-2003, 08:33 PM
yield2s's Avatar
I DO. I DO.
very eazy,17mm wrench,and a strong hand for the filter. thats it.
make sure the filter o-ring comes off w/the old filter,oil-up the new filter gasket. hand tighten it and fill her up with 4.6qts of your favorite earl. Unless your a really good aim you'll need a funnel to filler up.
Old 10-23-2003, 10:59 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
^ what he said! easy as pie! i can do mine with out even jscking the car up, but im 6'5 so my arms are kinda long but its EASY
Old 10-24-2003, 08:55 AM
Martian's Avatar
Best part of changing your own is that you can use SYNTHETIC oil.
Old 10-24-2003, 08:59 AM
SK2003TypeS's Avatar
yeah, it's not rocketscience. Drain plug and filter are pretty close to each other. Filter is at a weird angle (depending on what car comparing too), but not to bad. If you have ramps, it'll make your life a lot easier.
Old 10-24-2003, 09:30 AM
VTEC11's Avatar
i have ramps, but i can't use them in my driveway since its made from blacktop and is soft..
sux ass man.. Anyone know what one can use on a blacktop driveway to raise the car a lil..
Old 10-24-2003, 09:48 AM
Mr Zipps's Avatar
I do my own also....
For some reason I feel better if I do things myself because I know they were done correctly and I know the products that I'm using....
I always feel like mechanics and dealers just put in the cheapest stuff on or in your car, so they can reap a bigger profit...
Old 10-24-2003, 10:06 AM
thejavagod's Avatar
cool thanks.
Old 10-24-2003, 10:50 AM
Hayll yes... Don't forget to replace the crush washer each time
Old 10-24-2003, 03:09 PM
DOLEFEE's Avatar
If you can't do it on your blacktop driveway and you don't have ramps, I suggest you drive the front passenger side up a curb to give you some clearance. Of course this would depend on how your curb/driveway is set up...
Old 10-24-2003, 03:47 PM
FTM
FTM's Avatar
Post
The dealer will put SYNTHETIC OIL in for you.
They will use what they have & charge you an arm with 2 legs or you can bring your own oil. My last oil change 3 weeks ago I had them put in my own MOBIL 1.
Old 10-24-2003, 04:14 PM
fsttyms1's Avatar
why cant you use the ramps on blacktop? they shouldn hurt it. ive used ramps many of times on blacktop with out a problem. other wise you can take a piece of ply wood a little longer (tire-ramp side)than the ramps (same width) and fasten them to the plywood... or you can buy the solid plastic ramps
Old 10-24-2003, 10:43 PM
VTEC11's Avatar
i was thinking about the plastic ramps, do they work well? I have the metal ramps which have sharp edges, and they sink into the blacktop.. I used a jack a long time ago in my uncle's blacktop and that too sinked in a few inches after like 10 mins...
HOw much do they plastic ones cost??
Old 10-25-2003, 12:50 AM
O.G.
BlackShadow's Avatar
I also change my own oil. Since my car is lowered, I have to drive it onto a 4x4 piece of plywood so I can get enough ground clearance to jack it up. Then it is smooth sailing from there.
mada51589
05-03-2022 08:54 PM
robm
09-18-2015 07:53 AM
pizokk1
09-17-2015 09:29 AM
datadr
09-12-2015 09:12 PM
Aleax
09-11-2015 11:31 AM
Quick Reply: Changing the oil yourself?
