Changing the cabin filter???
Does anybody have the instructions on how to change the cabin air filter? I remember seeing a thread about it last year but I can't seem to find it.
The filter is indeed behind your glove box. Remove the glove box by first unscrewing the side tabs and then removing the screws at the bottom. Once the box is out of the way, using wire cutters, you will need to clip off the cover at the center panel that is behind the glove box (this only needs to be done if it is the first time the fitlers are being changed). Once the cover has been removed, you have access to the two verticle filter holders and you can slide them out. Once out, replace the old filters with the new ones. Installation is the reverse with the exception that the clipped cover is installed horizontally with an insert tab on the left and a scres on the right side (Acura event provides the screw) It takes about 30 minutes.
