Changing 2000 TL A/C filter
I want to change the A/C filter as recommended in the TL maintenance guide but don't know where it is as the owner's manual doesn't share that info. Thanks for the help
it is behind the glove box, you need to use a utility knife to cut out the cover for the first filter change. not sure why they did it that way but it is easy. there are 2 filters 1 on top of the other in a bracket. pull out the bracket and replace them note the direction of airflow before you replace the old ones.
