car pulls to right..
I have a 01 TL and it keeps pulling to right(changes one lane in 5 seconds in 80mph). My last set of tires(stock) lasted about 40,000 miles but I noticed only outside of my right front tire was completly worn out. I did alignment few days ago with new set of tires(Kumho 225/55/16), but it still pulls to right. I check tire pressure every two weeks. Does anybody know what's problem with my car?
I think my sister once hit pothole hard, and it might be the problem..
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
this might not apply, but my sisters 00' accord (i think its based of the same platform) also pulls to the right, tried most of the things you did...i could use an answer too
Well if you had an alignment done and a new set of tires and the tire psi is ok.... I would swap the front tires side to side and see if it still pulls right.... or does it now pull left. If it pulls left you have a tire issue. If this didnt change anything put the tires back to the way they were and bring the car back to the shop and have them perform the alignment again....
coupe
coupe
I have the same problem and the Manager of A&H motor told me it's because of the slightly off caster setting, it is still within specification. He also told me that it can be fixed during my next tire replacement. So I'm not that worry!
Oakes
Wash & Wax
10-12-2015 11:17 AM
